Scale is not recognized in Miscellaneous entry only
Hello all!
I’ve been having this issue for some time now, the workstation is setup to receive the weight from a scale, it works fine in any other section except for the Miscellaneous entry, to capture weight I need to change the setup of the workstation to Prompt for weight.
Any suggestions are welcomed!
