Schedule Task's Triggered BPMs
The closest to the solution I've come is to create a pre-process bpm in this location: SysMonitor.UpdateSysMonitorSched
The bpm has the following content:
for each ttSysAgentTask where ttSysAgentTask.RowMod='U' OR ttSysAgentTask.RowMod='A' no-lock , each SysAgentSched where (ttSysAgentTask.AgentID = SysAgentSched.AgentID and ttSysAgentTask.AgentSchedNum = SysAgentSched.AgentSchedNum) no-lock.
{lib/PublishInfoMsg.i &InfoMsg = "'My debug message.'"  &InfoSeverity = {&MESSAGE_INFO}}.
end.
But I can't just get the bpm to be triggered when I create a new schedule task which shows up in the System Monitor.
Hello All:
I need to send out an email whenever there is a new schedule task in the vantage System Monitor. How do I trigger a BPM code when there is a new schedule task?
For example, when I need to send out an email every time the Demand Entry window is updated I use the code below.
Here are the locations of a few of the things I mentioned earlier. In case if helps:
Demand Entry Location: Sales Mgt > Demand Mgt > General Operations > Demand Entry
BPM Location: System Mgt
> Business Process Mgt > Setup > Method Directives > DemandEntry.Update > Post-Processing > New-Demand-Email
- CODE -
define variable SendMsg_from as character no-undo initial '':U.
define variable SendMsg_to as character no-undo initial '':U.
define variable SendMsg_cc as character no-undo initial '':U.
define variable SendMsg_subject as character no-undo initial '':U.
define variable SendMsg_body as character no-undo initial '':U.
define variable SendMsg_hEmailProc as handle no-undo.
define Variable ExpDate as character no-undo initial '':U.
define Variable User1 as Character.
run Bpm/BpmEmail.p persistent set SendMsg_hEmailProc.
Define variable Comments as character no-undo initial ' ':U.
DEFINE variable flag AS INTEGER.
ASSIGN flag = 0.
For Each Company no-lock.
assign SendMsg_from = 'edi@...'.
assign SendMsg_to = 'staff1@...; staff2@...;'.
End.
assign SendMsg_CC = SendMsg_CC + 'staff3@...'.
assign SendMsg_subject = SendMsg_subject + 'New EDI Demand Order'.
for first ttdemandhead where ttdemandhead.ReadyToProcess = True:
                assign SendMsg_body =
                'Customer: ' + ttdemandhead.CustomerNameDummy + CHR(10) + CHR(10) +
                'PO Number: ' + string(ttdemandhead.POrderNumberDummy) + CHR(10).
                assign flag = 1.
end.
if(flag = 1) and ttdemandhead.CustomerNameDummy <> ' ' then do.
run SendEmail in SendMsg_hEmailProc (
true,
CUR-COMP,
SendMsg_from,
SendMsg_to,
SendMsg_cc,
SendMsg_subject,
SendMsg_body,
"":U
end.
if valid-handle(SendMsg_hEmailProc) then delete procedure SendMsg_hEmailProc.
leave.
- END OF CODE –
Additional Details:
I’m running –
Vantage 8.03.409C
Released:
6/13/2010
