Scheduled Resource Table
Hey Drew..
The actual table that Epicor stores what specific resources are
scheduled for a particular operation is ResourceTimeUsed. On a side
note, give me a call, there are some things I'd like to discuss
regarding that and the email you sent the other day...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
Of drew.pete
Sent: Friday, April 08, 2011 10:54 AM
Subject: [Vantage] Scheduled Resource Table
Hello all,
On 905.602A - I'm looking to put together a BAQ report for projected
load on resources. So far, all I can find for resources on Jobs is in
the JobOpDtl table. I'd like to be using the table that houses the
"Scheduled Resources" found on the Scheduled Resources tab in Job Entry.
Does anyone know what table that information resides in?
Thanks!
Drew
Hello all,
On 905.602A - I'm looking to put together a BAQ report for projected load on resources. So far, all I can find for resources on Jobs is in the JobOpDtl table. I'd like to be using the table that houses the "Scheduled Resources" found on the Scheduled Resources tab in Job Entry. Does anyone know what table that information resides in?
Thanks!
Drew
Well, did some digging using the BL Tester and found the datasource. Says it's external which makes sense why I can't find a table named "JobResources".
Table: JobResources
JobResources.Company {EXTERNAL} String
JobResources.JobNum {EXTERNAL} String
JobResources.AssemblySeq {EXTERNAL} Int32
JobResources.OprSeq {EXTERNAL} Int32
JobResources.OpDtlSeq {EXTERNAL} Int32
JobResources.WhatIf {EXTERNAL} Boolean
JobResources.AllocNum {EXTERNAL} Int32
JobResources.ResourceGrpID {EXTERNAL} String
JobResources.ResourceID {EXTERNAL} String
JobResources.ResourceDesc {EXTERNAL} String
JobResources.CalendarName {EXTERNAL} String
JobResources.RowIdent {EXTERNAL} String
JobResources.RowMod {EXTERNAL} String
JobResources.DBRowIdent {EXTERNAL} Byte[]
Now just to figure out how in the world this information is calculated/determined?
--- In vantage@yahoogroups.com, "drew.pete" <drew.pete@...> wrote:
> Hello all,
> Thanks!
> Drew
Not sure if you've tried this already... In Job Entry, open Field Help
then choose "Technical Details". It will display the data binding for
each field, with table and column name.
Brian.
Of drew.pete
Sent: Friday, April 08, 2011 12:06 PM
Subject: [Vantage] Re: Scheduled Resource Table
"JobResources".
Table: JobResources
> Hello all,
> Thanks!
> Drew
