Scheduled WIP Capture
We are on 9.05.701
Using a process set for COS/WIP does appear to work. I recall it has dynamic parameters.
Although we have turned it off for the moment as soon as we were told that once it is run you won't be able to recall time records for dates prior to COS/WIP up to date.
Funnily on testing this it appears the information may be incorrect.
We are still coming across a lot of anomalies with regards to entering in time (labor). Weather this is just because our users are still coming to grips with changing systems or not is another thing.
The steps around generating AR invoices is rather long winded to say the least.
We are a services company and really only need to capture time by employees against projects.
Cheers
Simon Hall
--- In vantage@yahoogroups.com, "nustepvantage" <dpfiester@...> wrote:
> Hi All,
> The WIP Capture Process did work, but it only ran one days worth of transactions. It appears it ran the one day of transactions based on the day I set it up to run. I didn't change the date range prior to setting it up. I have the WIP Capture set to run again Friday evening. When I set up this time, I set the dates and also checked the appropriate checkboxes before assigning it to a task. We will see if this does the trick or not.
> Thanks,
> David
> --- In vantage@yahoogroups.com, "Kurt" <kurt.baker@> wrote:
> > Hi David,
> > Did this work for you?
> > Or, for anyone else who could help:
> > We're on 8.03.405 and I'm trying to do pretty much the same thing. I want to schedule the Capture COS/WIP Activity, but I need the checkboxes checked each time it runs. If I check the checkboxes and then use the 'Save Process Set' button, would this run like I need?
> > Any help is appreciated!
> > Kurt
> > --- In vantage@yahoogroups.com, "nustepvantage" <dpfiester@> wrote:
> > > Thanks Ted. I'll give it a try.
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
> > > --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > > > When you schedule a task, the options you choose will always run with the task. You can modify these by going into the system agent, selecting a task, go to actions and View Task Parameters.
> > > > ________________________________
> > > > From: nustepvantage <dpfiester@>
> > > > To: vantage@yahoogroups.com
> > > > Sent: Thursday, May 16, 2013 8:22 AM
> > > > Subject: [Vantage] Scheduled WIP Capture
> > > > Hi All,
> > > > I'm setting up a scheduled task to run our Capture COS/WIP Activity on a weekly basis.
> > > > Inside the Capture COS/WIP Activity window we always have to check the Post Cost of Sales/MFG Variance and Capture Outdated transactions checkboxes before running the process. Does anyone know if there is a way to automatically have these options checked before the process runs via the scheduled task?
> > > > Thanks,
> > > > David Pfiester
> > > > NuStep, Inc.
> > > > 734-418-1850
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> > > > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > > > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > [Non-text portions of this message have been removed]
Hi All,
David Pfiester
NuStep, Inc.
734-418-1850
Hi All,
David Pfiester
NuStep, Inc.
734-418-1850
David Pfiester
NuStep, Inc.
734-418-1850
> From: nustepvantage <dpfiester@...>
> Hi All,
> Thanks,
> David Pfiester
> NuStep, Inc.
> 734-418-1850
Hi David,
Kurt
> David Pfiester
> NuStep, Inc.
> 734-418-1850
> > Hi All,
> > Thanks,
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
Try in your test environment...We do similar for MRP and check the boxes needed and criteria etc and schedule it (without a process set).
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Kurt
Sent: Wednesday, May 29, 2013 10:45 AM
Subject: [Vantage] Re: Scheduled WIP Capture
Hi David,
Kurt
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "nustepvantage" <dpfiester@...<mailto:dpfiester@...>> wrote:
> David Pfiester
> NuStep, Inc.
> 734-418-1850
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ted Koch <tkoch77@> wrote:
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > Hi All,
> > Thanks,
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
When we were on the same version of Vantage, we had a problem using the
dynamic option with the dates.
The first time we scheduled it - it worked great.
The next time, it used the same dates and all the inventory transaction were
in the prior period.
You might want to test this if you are going to schedule this job.
Kurt
Sent: Wednesday, May 29, 2013 8:45 AM
Hi David,
Kurt
> David Pfiester
> NuStep, Inc.
> 734-418-1850
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Ted
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Hi All,
weekly basis.
scheduled task?
> > Thanks,
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
Thanks for the replies!
Cathy, I'm not going to use the Dynamic option, but yes, I've had Vantage pull that on me where it decides to change things all of a sudden after working.
Karen mentioned about running things without a process set. I really am not a Vantage guru and don't play one on tv. Mostly I do mods here through code, so I don't know all the ins and outs of Vantage workings. To me it looked like the way you schedule something to run is to use the 'Save Process Set' button and set it to a process set and use the schedule I have created. Maybe I'm off base as to how this is done? Is there an easier (and or more reliable) way to schedule this? I've looked at the 'Help', but that isn't very clear.
Thanks again for all the help and suggestions!
Kurt
> Kurt
> Hi David,
> Kurt
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> > > Hi All,
> weekly basis.
> scheduled task?
> > > Thanks,
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
I don't use Process Sets because I think they are more trouble than they're worth. Â If you select the schedule you want to use in your process, and check Recurring, and then press the submit button, the process will be stored in the System Agent under that schedule. Â It will continue to be executed according to that schedule until you delete it, even if you restart the server. Â The System Agent and the System Monitor found in Utilities are very useful for tracking and monitoring your scheduled processes. Â If you are going to run a process on a schedule, you'll want to use dynamic dates because you rarely want to run a process against a fixed date. Â It is more likely you'll want to run the process based on the current date or some offset from it.
Â
Steven G.
Sent: Wednesday, May 29, 2013 3:03 PM
Â
Kurt
> Kurt
> Hi David,
> Kurt
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> > > Hi All,
> weekly basis.
> scheduled task?
> > > Thanks,
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
A process set is really to schedule a few things to run at once – so if you want to run wip then another then another something, you add them to a process set, then schedule the process set instead of scheduling all three separately
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Wednesday, May 29, 2013 3:01 PM
Subject: Re: [Vantage] Re: Scheduled WIP Capture
I don't use Process Sets because I think they are more trouble than they're worth. If you select the schedule you want to use in your process, and check Recurring, and then press the submit button, the process will be stored in the System Agent under that schedule. It will continue to be executed according to that schedule until you delete it, even if you restart the server. The System Agent and the System Monitor found in Utilities are very useful for tracking and monitoring your scheduled processes. If you are going to run a process on a schedule, you'll want to use dynamic dates because you rarely want to run a process against a fixed date. It is more likely you'll want to run the process based on the current date or some offset from it.
Steven G.
From: Kurt <kurt.baker@...<mailto:kurt.baker%40granitemicrosystems.com>>
Kurt
-- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Cathy" <cathy@...<mailto:cathy@...>> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> Kurt
> Hi David,
> Kurt
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ,
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , Ted
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > > Hi All,
> weekly basis.
> scheduled task?
> > > Thanks,
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
Hi All,
David
--- In vantage@yahoogroups.com, "Kurt" <kurt.baker@...> wrote:
> Hi David,
> Kurt
> > David Pfiester
> > NuStep, Inc.
> > 734-418-1850
> > > Hi All,
> > > Thanks,
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
Again, thanks to everyone for the help! I know you all have many things of your own to be doing, but as I mentioned in an earlier post, I'm not that up on Vantage workings yet. From some of the replies, the scheduling still seems a little confusing. Can I just ask if I have a decent understanding of how to schedule (COS/WIP in this case)?
1)I start creating a schedule in the System Agent Maintenance.
2)Then a new Process Set ID in Process Set Maintenance using the newly created schedule.
3)After that, set the schedule I created in Schedule Process Set and check Recurring.
4)And finally, I set the COS/WIP the way I'd like it to run (set needed checkboxes), click the Save to Process Set button and in the Save to Process Set form, select the Process Set and click OK.
Does this sound like the correct way? Thanks very much for everyone's help.
Kurt
--- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@...> wrote:
> A process set is really to schedule a few things to run at once â€" so if you want to run wip then another then another something, you add them to a process set, then schedule the process set instead of scheduling all three separately
> Steven G.
> Kurt
> -- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Cathy" <cathy@<mailto:cathy@>> wrote:
> > Kurt
> > Hi David,
> > Kurt
> > > David Pfiester
> > > NuStep, Inc.
> > > 734-418-1850
> > > > Hi All,
> > weekly basis.
> > scheduled task?
> > > > Thanks,
> > > > David Pfiester
> > > > NuStep, Inc.
> > > > 734-418-1850
