Scheduling Engineering Operations
You could always not add those ops until they are needed on the job…..once the others are finished.
Manasa
Sent: Wednesday, March 04, 2015 2:36 PM
Subject: Re: [Vantage] Scheduling Engineering Operations
I think we are close to coming up with a solution will let the group know
On Wednesday, March 4, 2015 2:22 PM, "Sarah Vareschi sarah.vareschi@... [vantage]" <vantage@yahoogroups.com> wrote:
We have the same scenario and the same limitation as you have.  We have never found an acceptable workaround.  It would be really great if there was something similar to the "related operation" on the subassembly which could indicate that it can't start until AFTER the opr specified is complete.
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
We are trying to constrain our job sub-assembly operations from being started until our four engineering operations are completed (drafting, checking, engineer review, MOM review). We have those four operations up underneath the parent assembly. But in scheduling the lower level assemblies it doesn't look at the dependency on those operations and are getting scheduled ahead of our engineering operations if the capacity if available through finite scheduling
We are trying to use either an engineering part, non-stock, marked as constrained, that gets built on a make to job demand link. We schedule the engineering job to build the "engineering" material, and then when it is received into the parent job allow those operations to schedule forward
Any other suggestions on setting up assemblies and operations within a job so those operations don't schedule to start until the other 4 operations are completed?
Maybe I don’t understand your example, but I assume you’re calling out a related operation from the sub’s to the parent.. have you looked at tying them to the last of those engineering ops and then forward scheduling? I’m trying to visualize the indented structure your describing..
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-3119
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Wednesday, March 04, 2015 10:41 AM
To: Vantage User Group
Subject: [Vantage] Scheduling Engineering Operations
So basically one structure/job assembly. Tied to the top level assembly are the following operations:
Op1 - Draft
Op2 - Check
Op3 - Review
Op4 - Set up MOM
Then 8 assemblies, each with their own materials and operations. I want to schedule so that the first operation of the 8 assemblies do not start until the Set up MOM operation has been completed
On Wednesday, March 4, 2015 12:22 PM, "Rob Bucek rbucek@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-808201793yiv6203440934ygrp-text">
  <div>Maybe I don’t understand your example, but I assume you’re calling out a related operation from the sub’s to the parent.. have you looked at tying them to the last of those engineering ops and then forward scheduling?  I’m trying to visualize the indented structure your describing..
Rob Bucek
FAX: (715)284-4084
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934 -- #ygrps-yiv-808201793yiv6203440934ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp #ygrps-yiv-808201793yiv6203440934hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp #ygrps-yiv-808201793yiv6203440934ads {
margin-bottom:10px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp .ygrps-yiv-808201793yiv6203440934ad {
padding:0 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp .ygrps-yiv-808201793yiv6203440934ad p {
margin:0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mkp .ygrps-yiv-808201793yiv6203440934ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ygrp-lc {
font-family:Arial;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ygrp-lc #ygrps-yiv-808201793yiv6203440934hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ygrp-lc .ygrps-yiv-808201793yiv6203440934ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity span {
font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity span span {
color:#ff7900;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934activity span .ygrps-yiv-808201793yiv6203440934underline {
text-decoration:underline;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934attach div a {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934attach img {
border:none;padding-right:5px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934attach label a {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934bold a {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 dd.ygrps-yiv-808201793yiv6203440934last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 dd.ygrps-yiv-808201793yiv6203440934last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 dd.ygrps-yiv-808201793yiv6203440934last p span.ygrps-yiv-808201793yiv6203440934yshortcuts {
margin-right:0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934attach-table div div a {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934attach-table {
width:400px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934file-title a, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934file-title a:active, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934file-title a:hover, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934file-title a:visited {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934photo-title a, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934photo-title a:active, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934photo-title a:hover, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div.ygrps-yiv-808201793yiv6203440934photo-title a:visited {
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 div#ygrps-yiv-808201793yiv6203440934ygrp-mlmsg #ygrps-yiv-808201793yiv6203440934ygrp-msg p a span.ygrps-yiv-808201793yiv6203440934yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934green {
color:#628c2a;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 o {
font-size:0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934photos div {
float:left;width:72px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934reco-category {
font-size:77%;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934reco-desc {
font-size:77%;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 .ygrps-yiv-808201793yiv6203440934replbq {
margin:4px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg select, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 input, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg pre, #ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 code {
font:115% monospace;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-mlmsg #ygrps-yiv-808201793yiv6203440934logo {
padding-bottom:10px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-msg p#ygrps-yiv-808201793yiv6203440934attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-reco #ygrps-yiv-808201793yiv6203440934reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-sponsor #ygrps-yiv-808201793yiv6203440934ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-text {
font-family:Georgia;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-text tt {
font-size:120%;}
#ygrps-yiv-808201793 #ygrps-yiv-808201793yiv6203440934 #ygrps-yiv-808201793yiv6203440934ygrp-vital ul li:last-child {
border-right:none !important;}
The only way we got this to work was to have a separate engineering job and not release the production job.  We had engineering as a part number for the engineering job and then as a material number on the production job, then linked the two jobs.
Manasa
Sent: Wednesday, March 04, 2015 11:41 AM
Ok, so have you set the subassembly so that it’s tied to Op4 – Set up MOM (related Operation 4) and then used a forward scheduling technique?
Rob Bucek
FAX: (715)284-4084
Sent: Wednesday, March 04, 2015 11:52 AM
Op1 - Draft
Op2 - Check
Op3 - Review
Op4 - Set up MOM
Rob Bucek
FAX: (715)284-4084
Yes exactly. Not getting it to line up though
On Wednesday, March 4, 2015 1:00 PM, "Rob Bucek rbucek@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1373329017yiv9558335238ygrp-text">
  <div>Ok, so have you set the subassembly so that it’s tied to Op4 – Set up MOM (related Operation 4) and then used a forward scheduling technique?
Rob Bucek
FAX: (715)284-4084
Op1 - Draft
Op2 - Check
Op3 - Review
Op4 - Set up MOM
Rob Bucek
FAX: (715)284-4084
</div>
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238 -- #ygrps-yiv-1373329017yiv9558335238ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp hr {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp #ygrps-yiv-1373329017yiv9558335238hd {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp #ygrps-yiv-1373329017yiv9558335238ads {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp .ygrps-yiv-1373329017yiv9558335238ad {
padding:0 0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp .ygrps-yiv-1373329017yiv9558335238ad p {
margin:0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mkp .ygrps-yiv-1373329017yiv9558335238ad a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ygrp-lc #ygrps-yiv-1373329017yiv9558335238hd {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ygrp-lc .ygrps-yiv-1373329017yiv9558335238ad {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238actions {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity span {
font-weight:700;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity span:first-child {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity span a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity span span {
color:#ff7900;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238activity span .ygrps-yiv-1373329017yiv9558335238underline {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238attach {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238attach div a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238attach img {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238attach label {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238attach label a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238bold {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238bold a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 dd.ygrps-yiv-1373329017yiv9558335238last p a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 dd.ygrps-yiv-1373329017yiv9558335238last p span {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 dd.ygrps-yiv-1373329017yiv9558335238last p span.ygrps-yiv-1373329017yiv9558335238yshortcuts {
margin-right:0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238attach-table div div a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238attach-table {
width:400px;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238file-title a, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238file-title a:active, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238file-title a:hover, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238file-title a:visited {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238photo-title a, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238photo-title a:active, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238photo-title a:hover, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div.ygrps-yiv-1373329017yiv9558335238photo-title a:visited {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 div#ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg #ygrps-yiv-1373329017yiv9558335238ygrp-msg p a span.ygrps-yiv-1373329017yiv9558335238yshortcuts {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238green {
color:#628c2a;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 o {
font-size:0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238photos div {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238photos div div {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238photos div label {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238reco-category {
font-size:77%;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238reco-desc {
font-size:77%;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 .ygrps-yiv-1373329017yiv9558335238replbq {
margin:4px;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-actbar div a:first-child {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg table {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg select, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 input, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 textarea {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg pre, #ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 code {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg * {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-mlmsg #ygrps-yiv-1373329017yiv9558335238logo {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-msg p a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-msg p#ygrps-yiv-1373329017yiv9558335238attach-count span {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-reco #ygrps-yiv-1373329017yiv9558335238reco-head {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-reco {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ov li a {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ov li {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-sponsor #ygrps-yiv-1373329017yiv9558335238ov ul {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-text {
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1373329017 #ygrps-yiv-1373329017yiv9558335238 #ygrps-yiv-1373329017yiv9558335238ygrp-vital ul li:last-child {
Thanks Manasa, I tried that as well but it would not schedule the production job after the completion of the material
On Wednesday, March 4, 2015 12:58 PM, "Manasa Reddy manasa.reddy@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1387859448yiv6369109995ygrp-text">
  <div>
Manasa
</div>
<div class="ygrps-yiv-1387859448yiv6369109995yqt6433037636" id="ygrps-yiv-1387859448yiv6369109995yqt81055"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995 -- #ygrps-yiv-1387859448yiv6369109995ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp hr {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp #ygrps-yiv-1387859448yiv6369109995hd {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp #ygrps-yiv-1387859448yiv6369109995ads {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp .ygrps-yiv-1387859448yiv6369109995ad {
padding:0 0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp .ygrps-yiv-1387859448yiv6369109995ad p {
margin:0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mkp .ygrps-yiv-1387859448yiv6369109995ad a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ygrp-lc #ygrps-yiv-1387859448yiv6369109995hd {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ygrp-lc .ygrps-yiv-1387859448yiv6369109995ad {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995actions {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity span {
font-weight:700;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity span:first-child {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity span a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity span span {
color:#ff7900;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995activity span .ygrps-yiv-1387859448yiv6369109995underline {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995attach {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995attach div a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995attach img {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995attach label {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995attach label a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995bold {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995bold a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 dd.ygrps-yiv-1387859448yiv6369109995last p a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 dd.ygrps-yiv-1387859448yiv6369109995last p span {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 dd.ygrps-yiv-1387859448yiv6369109995last p span.ygrps-yiv-1387859448yiv6369109995yshortcuts {
margin-right:0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995attach-table div div a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995attach-table {
width:400px;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995file-title a, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995file-title a:active, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995file-title a:hover, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995file-title a:visited {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995photo-title a, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995photo-title a:active, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995photo-title a:hover, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div.ygrps-yiv-1387859448yiv6369109995photo-title a:visited {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 div#ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg #ygrps-yiv-1387859448yiv6369109995ygrp-msg p a span.ygrps-yiv-1387859448yiv6369109995yshortcuts {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995green {
color:#628c2a;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 o {
font-size:0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995photos div {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995photos div div {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995photos div label {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995reco-category {
font-size:77%;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995reco-desc {
font-size:77%;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 .ygrps-yiv-1387859448yiv6369109995replbq {
margin:4px;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-actbar div a:first-child {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg table {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg select, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 input, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 textarea {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg pre, #ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 code {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg * {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-mlmsg #ygrps-yiv-1387859448yiv6369109995logo {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-msg p a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-msg p#ygrps-yiv-1387859448yiv6369109995attach-count span {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-reco #ygrps-yiv-1387859448yiv6369109995reco-head {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-reco {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ov li a {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ov li {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-sponsor #ygrps-yiv-1387859448yiv6369109995ov ul {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-text {
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1387859448 #ygrps-yiv-1387859448yiv6369109995 #ygrps-yiv-1387859448yiv6369109995ygrp-vital ul li:last-child {
Send me a screen shot from the scheduling board of the results you are getting
Rob Bucek
FAX: (715)284-4084
Sent: Wednesday, March 04, 2015 12:03 PM
Rob Bucek
FAX: (715)284-4084
Op1 - Draft
Op2 - Check
Op3 - Review
Op4 - Set up MOM
Rob Bucek
FAX: (715)284-4084
We don’t currently have engineering ops on any of our jobs but I have been thinking about the best way to tie it all together and get them onto our jobs. I was thinking of not doing it as a separate operation and just having different statuses in the system for the job to become available for our production dashboard. What are your thoughts on this? Is that too simple?
Josh Serwe
Wisconsin Converting Inc.
Production Planning & Logistics
(920)437-6400 x 327
Sent: Wednesday, March 04, 2015 12:00 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Scheduling Engineering Operations
Rob Bucek
FAX: (715)284-4084
Op1 - Draft
Op2 - Check
Op3 - Review
Op4 - Set up MOM
Rob Bucek
FAX: (715)284-4084
<div id="ygrps-yiv-15199660yiv8043522235ygrp-text">
  <div></div><div dir="ltr"><span></span><div>We have the same scenario and the same limitation as you have.&nbsp; We have never found an acceptable workaround.&nbsp; It would be really great if there was something similar to the &quot;related operation&quot; on the subassembly which could indicate that it can&#39;t start until AFTER the opr specified is complete. </div><div><br clear="none"></div><div><br clear="none"></div><div><br clear="none"></div><div></div><div></div><div></div><div></div><div></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div></div><div style="color:rgb(0,0,0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255,255,255);"></div><div></div><div></div><div></div><div style="background-color:rgb(255,255,255);"></div><blockquote><span title="qreply"> <blockquote class="ygrps-yiv-15199660yiv8043522235gmail_quote" style="margin:0px 0px 0px 0.8ex;border-left-color:rgb(204,204,204);border-left-width:1px;border-left-style:solid;"></blockquote><div><br clear="none"></div><div></div><div></div><div></div><div></div><div></div><div></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div></div><div style="color:rgb(0,0,0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255,255,255);"><br clear="none"></div><div></div><div></div><div></div><div></div><div></div><div></div><div></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div style="font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;"></div><div></div><div style="color:rgb(0,0,0);font-family:HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif;font-size:16px;background-color:rgb(255,255,255);"></div><div></div><div></div><div></div><div style="background-color:rgb(255,255,255);"></div><blockquote class="ygrps-yiv-15199660yiv8043522235gmail_quote" style="margin:0px 0px 0px 0.8ex;border-left-color:rgb(204,204,204);border-left-width:1px;border-left-style:solid;"></blockquote></span></blockquote></div>
</div>
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235 -- #ygrps-yiv-15199660yiv8043522235ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp hr {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp #ygrps-yiv-15199660yiv8043522235hd {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp #ygrps-yiv-15199660yiv8043522235ads {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp .ygrps-yiv-15199660yiv8043522235ad {
padding:0 0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp .ygrps-yiv-15199660yiv8043522235ad p {
margin:0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mkp .ygrps-yiv-15199660yiv8043522235ad a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ygrp-lc {
font-family:Arial;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ygrp-lc #ygrps-yiv-15199660yiv8043522235hd {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ygrp-lc .ygrps-yiv-15199660yiv8043522235ad {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235actions {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity span {
font-weight:700;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity span:first-child {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity span a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity span span {
color:#ff7900;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235activity span .ygrps-yiv-15199660yiv8043522235underline {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235attach {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235attach div a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235attach img {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235attach label {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235attach label a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235bold {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235bold a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 dd.ygrps-yiv-15199660yiv8043522235last p a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 dd.ygrps-yiv-15199660yiv8043522235last p span {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 dd.ygrps-yiv-15199660yiv8043522235last p span.ygrps-yiv-15199660yiv8043522235yshortcuts {
margin-right:0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235attach-table div div a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235attach-table {
width:400px;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235file-title a, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235file-title a:active, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235file-title a:hover, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235file-title a:visited {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235photo-title a, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235photo-title a:active, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235photo-title a:hover, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div.ygrps-yiv-15199660yiv8043522235photo-title a:visited {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 div#ygrps-yiv-15199660yiv8043522235ygrp-mlmsg #ygrps-yiv-15199660yiv8043522235ygrp-msg p a span.ygrps-yiv-15199660yiv8043522235yshortcuts {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235green {
color:#628c2a;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 o {
font-size:0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235photos div {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235photos div div {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235photos div label {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235reco-category {
font-size:77%;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235reco-desc {
font-size:77%;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 .ygrps-yiv-15199660yiv8043522235replbq {
margin:4px;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-actbar div a:first-child {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg table {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg select, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 input, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 textarea {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg pre, #ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 code {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg * {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-mlmsg #ygrps-yiv-15199660yiv8043522235logo {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-msg p a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-msg p#ygrps-yiv-15199660yiv8043522235attach-count span {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-reco #ygrps-yiv-15199660yiv8043522235reco-head {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-reco {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ov li a {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ov li {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-sponsor #ygrps-yiv-15199660yiv8043522235ov ul {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-text {
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-text tt {
font-size:120%;}
#ygrps-yiv-15199660 #ygrps-yiv-15199660yiv8043522235 #ygrps-yiv-15199660yiv8043522235ygrp-vital ul li:last-child {
#ygrps-yiv-15199660
