Scheduling MRP in Vantage 6
That process only works in Vantage 8. I ran into the same problem in Vantage 6, and I never found a way around it....
--- In vantage@yahoogroups.com, "Adrian Lauchlan" <adrianlauchlan@...> wrote:
> Go to System Agent under Utilities, create a new schedule - call it MRP Run
> Net Change, schedule daily and chose the days you want it to run on and
> chose the time to run it. Do the same for the Full Regen schedule.
> Then go to Process MRP - set up your parameters and at the bottom under
> schedule chose the relevant schedule and then click Process.
> Your MRP runs should now happen when you want them to
> Adrian
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Mike
> Sent: 16 July 2012 15:54
> To: vantage@yahoogroups.com
> Subject: [Vantage] Scheduling MRP in Vantage 6
> I'm looking to schedule the processing of mrp. I would like it to run a Net
> Change every night Monday - Friday. Then, on Saturday a Full Regen.
> Any ideas on how to automate this with a batch script or anything?
I'm looking to schedule the processing of mrp. I would like it to run a Net Change every night Monday – Friday. Then, on Saturday a Full Regen.
Adrian
Mike
