Scheduling W2K Defrag Using Bat File
Gary and John-
I found this ages ago. I don't know that I ever got it to work, but
here it is...
Defragmentation on W2K
From a command prompt:
runas /user:csmachine\administrator "mmc dfrg.msc"
The user is prompted for the administrator password. This command may be
useful
for an administrator who wants to run a defragmentation on a user's
computer
without forcing the user to log off.
- OR -
You can also use the following procedure to schedule the Dfrg.msc
console to run
on a user's desktop in the context of the administrators account. This
allows a
normal user to manually defragment drives without performing any other
unauthorized administrative tasks.
1. From another networked computer in the domain, log on as a user who
has
administrator privileges.
2. At a command prompt, type the following command
at \\<machine_name> 5:00pm /interactive /every:f
c:\winnt\system32\dfrg.msc
where <machine_name> is the name of a normal user's computer.
You can adjust the command to fit your needs. The above example starts
the
defragmenter console on the user's computer with administrative rights
every
Friday at 5:00 P.M. so the user can manually select and start a
defragmentation
process.
Or, an administrator could build a batch file with separate lines for
each
workstation without using the /every switch, and then run the batch file
manually whenever users should run a defragment operation.
Good Luck! I hope this helps!
Steven Russell
C & S Machine Products, Inc.
Message: 1
Date: Thu, 15 Aug 2002 19:52:20 -0000
Subject: Re: Scheduling W2K Defrag Using Bat File
Gary,
I went through this a few months back. According to what I read, the
stripped-down version of Diskeeper (WIN2K Defrag) requires direct
user intervention and could not be scheduled to run automatically.
If you do come up with a way to make it happen, I'd like to hear
about it. Good luck.
John Elder
Penn State Tool & Die
--- In vantage@y..., "Gary Polvinale" <garyp@d...> wrote:
> You're supposed to be able to schedule Defrag utility that comes
with W2K
> (basically Diskeeper) using a batch file and the W2K task
scheduler. I
> couldn't find anything in windows help or on the microsoft support
site
> about this. I want to be able to run it overnight on all the
workstations.
> Does anyone know how this is done?
> Gary
You're supposed to be able to schedule Defrag utility that comes with W2K
(basically Diskeeper) using a batch file and the W2K task scheduler. I
couldn't find anything in windows help or on the microsoft support site
about this. I want to be able to run it overnight on all the workstations.
Gary
Gary,
John Elder
with W2K
scheduler. I
site
workstations.
> Gary
