Schema update or no?
I've restored an older database (backed up when the app was previous
version) for a test. I had to run admin tools and answer yes to the
"run mandatory conversions" question. No schema change was required in
my case (9.05.602a SQL -> .603), but you can run it and see if it has
work to do.
Brian.
Of Nick
Sent: Wednesday, May 18, 2011 6:15 PM
Subject: [Vantage] Schema update or no?
When we first setup E9, we were on 9.05.601b. We made a virgin DB at the
time. We have since upgraded to 9.05.604a. When we setup 601b, we made a
backup of the DB. IF i was going to restore to that version of the DB,
do i
need to run a schema update as well?
Nick
backup of the DB. IF i was going to restore to that version of the DB, do i
Nick
…. I have never tried to downgrade unless I am misunderstanding you.
If you are restoring the backup you made in 601b and you plan to let it upgrade to 604 you will not need to run a schema update. However you will need to run conversion.
"Zac" Jason Woodward
Network Administrator
Intermountain Electronics, Inc.
O: 877-544-2291
M: 435-820-6515
F: 435-637-9601
www.ie-corp.com
Creating customer confidence through extraordinary service and experienced industry experts.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nick
Sent: Wednesday, May 18, 2011 4:15 PM
Nick
