Scrap Factor on BOM's
Michelle, with the risk of losing Epicor support, I would not recommend any mass updates to the back-end directly. Have you contacted the customization group to get a quote from them to see what it would take-then you won't risk the response "well we didn't do the conversion/update blah blah, so we can't support you". This seems like a minor update to do but they would engage the adequate development know-how (methinks rationally) with all the tables and relationship knowledge to do this for you.
Just my humble .02!
We are on Vantage 8.03.404A. Our BOMs were built without a scrap factor
on the raw materials. Is the only way to get the scrap factor on the
BOM now other then to check out each individual part, add the factor,
approve and then check the part back in? Is there any way to mass
update this factor for all BOM's? We have thousands of BOM's and I am
looking for a shortcut on how to do accomplish this task. Does anyone
have any suggestions?
Michelle C. Grman
Assistant Controller
KERUSSO
The Greek word means - To herald divine truth as a public crier; to
preach the gospel.
P.O. Box 32
Berryville, AR 72616
Phone: 870-423-6242 Ext. 267
Fax: 870-423-3568
Web Site: www.kerusso.com
"A well-stocked display is a well-shopped display."
Let us help you optimize your Kerusso inventory levels--and MAXIMIZE
your sales!
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
Michelle,
If you are adventurous, you can do it via an ODBC UPDATE routine - although I strongly urge you to try it on a copy of your live db and thoroughly test the results first.
Data maps (typically used to transfer data from a legacy system to vantage) are also available for a price.
Rob Brown
--- On Tue, 6/24/08, Michelle C. Grman <mcgrman@...> wrote:
Subject: [Vantage] Scrap Factor on BOM's
Date: Tuesday, June 24, 2008, 5:20 PM
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Phone: Ext. 267
Fax:
Web Site: www.kerusso. com
your sales!
at:
