Looking for some technical information. When you create a process with the SDK, is it beholden to the Company separation logic? Or can you create your solution globally?
I haven’t run across anything that would lead me to believe that SDK services would be company specific, but I didn’t really test anything out as I didn’t assume it would be a problem either. Have you seen something that would lead you to believe that it is? I can do some tests tomorrow if you have a specific issue.
We don’t have it. I was asking as some of the development I could envision us doing we would want the data to be global. Right now we have to define everything we need in each company. If I have the ability to use the SDK I was hoping we could set the processes and data to be globally available without having to keep the data in sync between the companies. I’m assuming the Multi-Company process would not cover data that was added in SDK tables?
Yeah, the SDK tables don’t automatically have the company field. I had to actually add it when I wanted it. So no, it’s not required.
