Search SCR's - Email found in subject
Make sure you use web\<NAME> for the login ID. If you don't put the web\ in front it won't work.
Ken
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of pbparker
Sent: Wednesday, April 27, 2011 1:24 PM
Subject: [Vantage] Re: Search SCR's - Email found in subject
Do you need to get an invite to use this? My Epicweb credentials aren't allowing me access to this site.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Stephen Edginton <stephene@...> wrote:
> Just in case people are not aware of this...
> You can now search for SCR's
> http://bit.ly/eYK3FP
> https://scrs.epicor.com
> Regards,
> Stephen Edginton (Beng) | Development Director
> Dot Net IT Limited, 1 St Kenelm Court, Steel Park Road, Halesowen, West Midlands, B62 8HD | Tel: 0121 559 6700 | Mobile:07734858415 | Email:stephene@...
> This e-mail and any files transmitted with it are confidential and are intended solely for the use of the intended recipient(s). If you are not the intended recipient, you must not copy, distribute or take any action based on this communication. If you have received this communication in error please contact Stephene@...<mailto:Stephene@...> and delete this communication and any copies of it. Any views or opinions presented are soley of those of the author and do not necessarily represent those of Dot Net IT Limited.
> Dot Net IT Limited, Reg No 4412519
Regards,
I love being able to search SCRs again! I'm also happy that it is covering both Epicor 9 and Vantage 8. Searching is versatile and it's fast. So far, I've easily been able to find what I was looking for. It's nice to see if an issue has been reported. When our users report a problem it's nice to check and see if there's a known issue (often it turns out being operator error). I think it's a plus on the support side and lets me do some research on my own rather than always having to contact support and wait for a reply. The availability of the Customer Matrix Viewer will be a big time saver for me! My wish list is for: 1. What version did the bug appear in? (would be nice to know if I'm upgrading to a version with a known issue); 2. Add a SCR status for "Complete, not Released"; 3. Ability to filter by status (Open SCRs only); 4. Workarounds and Availability of one-off fixes.
Sue
> Regards,
Glad to hear it works for someone! Regardless of what I search for I receive the following error: 500 - Internal server error. There is a problem with the resource you are looking for, and it cannot be displayed.
Anyone else getting this error?
Virginia Joseph
Deep Hole Specialists, LLC
> Sue
> > Regards,
> > This e-mail and any files transmitted with it are confidential and are intended solely for the use of the intended recipient(s). If you are not the intended recipient, you must not copy, distribute or take any action based on this communication. If you have received this communication in error please contact Stephene@<mailto:Stephene@> and delete this communication and any copies of it. Any views or opinions presented are soley of those of the author and do not necessarily represent those of Dot Net IT Limited.
Yes, Virginia, I'm getting the same error as you.
I was able to have the "Help" section display once, but I can't even get that to display now. All entries that I attempt to make using the Module Codes result with that same error.
I haven't yet bothered to contact Epicor - from the copied email, I wasn't sure if Support would know how to direct it. The copied email doesn't look like it includes the Epicor contact information, either. I thought that I would try later...
Let us know if you're able to resolve this - thanks!
Laraine
> Thanks,
> Virginia Joseph
> > Sue
> > > Regards,
> Regards,
Hi All,
I just received a notice from Neil McLachlan at Epicor, and the service is now back up and available. I re-tried it, entered a couple of different Module Codes, and results appeared. Yay!
As far as your credentials, you do need to use your Epicor user login with "web\username" as the login. There is a document on the Epicor site called "Customer Matrix Viewer" which provides instructions and more information about the Viewer.
Good luck!
Laraine
> > Regards,
