Search through SubShipD Table records using SubShipConEntry Adapter
I set up a simple search using the wizard in the customization screen. How do I search through the SubConShipD table to get data from multiple rows based on the PackNum?
private void SearchOnsubconshipentryShowDialog()
                            // Wizard Generated Search Method
                            // You will need to call this method from another method in custom code
                            // For example, [Form]_Load or [Button]_Click
                            bool recSelected;
                            string whereClause = string.Empty;
                            System.Data.DataSet dssubconshipentry = Ice.UI.FormFunctions.SearchFunctions.listLookup(this.oTrans, "subconshipentry", out recSelected, true, whereClause);
                            if (recSelected)
                                            System.Data.DataRow adapterRow = dssubconshipentry.Tables[0].Rows[0];
                                            // Map Search Fields to Application Fields
                                            EpiDataView edvUD100 = ((EpiDataView)(this.oTrans.EpiDataViews["UD100"]));
                                            System.Data.DataRow edvUD100Row = edvUD100.CurrentDataRow;
                                            if ((edvUD100Row != null))
                                                            edvUD100Row.BeginEdit();
                                                            edvUD100Row["Key1"] = adapterRow["PackNum"];
                                                            edvUD100Row.EndEdit();
                            bool recSelected;
                            if (recSelected)
