Use MRP to help manage the change.
Two different approaches -
A) Place ABC2 on the Sales Kit
Place ABC1 as the only component on the BOM for ABC2, make it effective now.
When MRP runs, a job will be recommended for ABC2, your planner can look at
the inventory position of ABC1 and when it runs out, place the real BOM
under ABC2
B) Leave ABC1 on the sales kits.
Place ABC2 as the only component on the BOM for ABC1, make it effective now.
When MRP runs a new job will be recommended for ABC1 (if you don't have
inventory) and ABC2 will also have a demand.
After the inventory runs out, go into the Sales kits and replace ABC1 with
ABC2.
Bruce
bruce@...
www.ERPgeek.com
pbriscoe10
Sent: Monday, June 15, 2009 10:09 PM
Subject: [Vantage] Seeking Ideas: Phasing In New Part Numbers
Hello,
We would like to phase in new part numbers and are thinking of the best way
of going about it.
We build kits. The components of these kits will be undergoing some changes
that require us to change their part numbers. What we would like to do is
slowly phase in the new part numbers whenever inventory for the current part
number is depleted. For example, when kit component ABC1 has its inventory
depleted, we would like Vantage to automatically switch over to the new part
number ABC2.
Our Concept:
We are trying to find a way for the system (MRP) to recognize when ABC1 runs
out of stock and then switch over and start making ABC2 to replace ABC1. We
thought that by selecting the "Run Out" option and deselecting "Run MRP" on
Part Maintenance of ABC1 we would stop MRP from suggesting new jobs for it;
it did. We also thought that by adding ABC2 as a substitute part to ABC1, we
could have MRP start creating jobs for ABC2 once ABC1 was depleted and had
the "Run Out" option selected; it did not.
Idealy, we would like to see MRP suggest a job to create ABC2 and use it to
fulfill the demand for ABC1. However; it seems that this is not how the
relationship works. If anyone has any suggestions as to how we could go
about phasing in our new part numbers (which must be done) while still being
able to use up the stock of our old part numbers, we would love to hear
them.
Note: The option of moving our quantities over from the old part numbers to
the new ones and then rebuilding our kits won't really work since we won't
know right away what the new part numbers are going to be (customer
dependent).
Thank you.
under ABC2
ABC2.
Bruce
bruce@...
www.ERPgeek.com
pbriscoe10
Hello,
of going about it.
number ABC2.
Our Concept:
them.
dependent).
Thank you.
