Call in and reference my Call Number: 3079448ESC
I think this is the same issue you are referring to. They provided a patch to fix the issue. I got the patch back on 11/30/2012.
Sent: Friday, February 15, 2013 11:23 AM
Subject: [Vantage] Re: Selecting records in BAQ and/or Dashboard
I will agree with Jose, but be careful. We are on 9.05.700C and a display filter with a calculated field in it will give us erroneous results. We upgraded several weeks ago from 9.05.603 to 9.05.700C and are having to remove these filters to make BAQ's work.
We have a support call in on this and it is a known bug for this level.
We then move the filter to the dashboard or report level as a work around.
FYI
Brad Boes
Metalworks
FYI
Brad Boes
Metalworks
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Just add a Filter on your Dashboard to look at the Calc Field..
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
>Â <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
>Â <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
>Â <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Fri, Feb 15, 2013 at 11:10 AM, stanchmura <schmura@...> wrote:
> > Hi:
> > Is there a way either in a BAQ or resulting dashboard to select records
> > from a calculated field? e.g. I need to monitor parts on hand that have no
> > associated cost. The calculatd field then is from the part table: Avg labor
> > + Burden + materials + subcontract=Total part cost. I need the
> > BAQ/Dashboard to siplay only those parts with the Total Calculated part
> > cost at 0.
> >Â
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
