[Semi-OT] Task Scheduler
The username and password were correct but I have found the culprit. MS-
KnowledgeBase article Q222628 states (paraphrased) "In order to schedule
jobs on a BDC the account being used must have 'Log on as batch job" set in
the user rights policy settings". When I added "Administrators" to the
"Logon as Batch Job" rights group it began working as you describe. If I
hadn't known it ought to work I might not have kept digging. Thanks.
-Todd C.
Sent: Wednesday, July 11, 2001 6:11 PM
Subject: Re: [Vantage] [Semi-OT] Task Scheduler
Todd,
Domain administrator can log into any PC on the domain with full rights,
that is it's purpose for existing. We run schedule on a BDC server to run
tape backups across the entire domain, and we run the scheduler 3 times a
day to do the vantage backvan.bat backup. You should have no problems as
long as the username & password you use in scheduler is the domain
administrator's.
Regards,
David Sloan
IT Manager
Entech Integrated Technologies
Phone: +61 8 8245 6789
Fax: +61 8 8245 6788
Direct Phone: +61 8 8245 6732
Postal Address: PO Box 1141, Marleston SA 5033
Site Address: 37 Belford Ave, Devon Pk SA 5008
email: dsloan@...
Web: http://www.entechgroup.net <http://www.entechgroup.net>
----- Original Message -----
To: 'vantage@yahoogroups.com'
Sent: Wednesday, July 11, 2001 10:29 PM
Subject: RE: [Vantage] [Semi-OT] Task Scheduler
Thanks David, that brings to mind that the server I am scheduling on is a
BDC to our NT-SBS Primary. With SBS you can have only one PDC. I'm not
sure if I can grant domain admin to the user from the perspective of the
server I am scheduling on. Hmmm... you've given me another place to look.
Thanks again.
-Todd
Sent: Tuesday, July 10, 2001 6:33 PM
AFAIK, Every time you change something in the schedule on the server, you
must re-enter the administrator name & password, otherwise it will not
work
(must confirm changes). Also this must be run as the Domain administrator
account & not a local administrator account
Apart from that, go into user manager & check your Administrator rights.
Regards,
David Sloan
IT Manager
email: dsloan@...
Web: http://www.entechgroup.net <http://www.entechgroup.net> <
http://www.entechgroup.net <http://www.entechgroup.net> >
Sent: Wednesday, July 11, 2001 5:49 AM
Subject: [Vantage] [Semi-OT] Task Scheduler
I am trying to use the task scheduler (NT 4.0 Sp4) to schedule some
regular
events similar to the nightly run of backvan.bat. I can create it using
the
AT command in RUN but whenever I try to modify it (using the scheduled
tasks
interface) it stops running and generates a "Could not start..." error.
The
log file shows it is having a problem with the logon info. The error
is:
The specific error is:
0x80070569: Logon failure: the user has not been granted the requested
logon type
at this computer.
Verify that the task's Run-as name and password are valid and try
again.
I am using the same username as the AT command creates (Administrator)
and
I
enter the same password I log in with so I am not sure what it is asking
for.
I have one task to schedule for about 40 times per day (ring the bell in
the
shop) and this is preventing me from adding scheduled times (rather than
using AT to setup 40 separate tasks). This could also be handy to
schedule
Vantage backups a few more times per day since it takes only 3 minutes
to
run and could be done between each shift. If anyone is familiar with the
Username/Password requirements in Task Scheduler and can point me in the
right direction I would very much appreciate it.
-Todd Caughey
Harvey Vogel Mfg. Co.
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> > Note: You must have
already linked your email address to a yahoo id to enable access.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
<http://docs.yahoo.com/info/terms/> Service.
I am trying to use the task scheduler (NT 4.0 Sp4) to schedule some regular
events similar to the nightly run of backvan.bat. I can create it using the
AT command in RUN but whenever I try to modify it (using the scheduled tasks
interface) it stops running and generates a "Could not start..." error. The
log file shows it is having a problem with the logon info. The error is:
logon type
at this computer.
Verify that the task's Run-as name and password are valid and try again.
I am using the same username as the AT command creates (Administrator) and I
for.
I have one task to schedule for about 40 times per day (ring the bell in the
using AT to setup 40 separate tasks). This could also be handy to schedule
Vantage backups a few more times per day since it takes only 3 minutes to
-Todd Caughey
AFAIK, Every time you change something in the schedule on the server, you must re-enter the administrator name & password, otherwise it will not work (must confirm changes). Also this must be run as the Domain administrator account & not a local administrator account
Regards,
David Sloan
IT Manager
email: dsloan@...
logon type
at this computer.
for.
-Todd Caughey
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
Thanks again.
-Todd
Regards,
David Sloan
IT Manager
email: dsloan@...
regular
the
tasks
The
logon type
at this computer.
I
for.
the
schedule
-Todd Caughey
Todd,
Domain administrator can log into any PC on the domain with full rights, that is it's purpose for existing. We run schedule on a BDC server to run tape backups across the entire domain, and we run the scheduler 3 times a day to do the vantage backvan.bat backup. You should have no problems as long as the username & password you use in scheduler is the domain administrator's.
Regards,
David Sloan
IT Manager
email: dsloan@...
Thanks again.
-Todd
Regards,
David Sloan
IT Manager
email: dsloan@...
regular
the
tasks
The
logon type
at this computer.
I
for.
the
schedule
-Todd Caughey
