Send e-mail on Job Prod Qty change
I Created a Post-Processing Action "send e-mail synchronously based on the test template". the E-mail is sent but the JobNum is not in the Body. I tried Insert - "field Query" & "Table Query" to add ttJobHead.JobNum
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> Try settings it up the way you had the other one. Use the template.
> From: vacortes21 <vcortes@...>
> To: vantage@yahoogroups.com
> Sent: Friday, June 8, 2012 3:48 PM
> Subject: [Vantage] Re: Send e-mail on Job Prod Qty change
> I created the BPM for JobEntry.Update but what Action do i used to send the email and have the JobNum, ProdQty in the Body?
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > If you just want to send out an email to tell someone the production qty has changed. Try creating the same bpm in JobEntry.Update.
> >Â From: vacortes21 <vcortes@>
> > Sent: Friday, June 8, 2012 2:12 PM
> >Â
> > What Actioin should I Use?
> > --- In vantage@yahoogroups.com, Miguel Santillan <msantillan@> wrote:
> > > I just ran into this and it seems you cannot pull data from cross tables using the wizard. You will need to write ABL code to send out the email. Look if JobEntry has JobNum and use that. It should being that A jobNum is needed to make a job entry.
> > > Regards,
> > > Miguel A. Santillan
> > > ERP Administrator
> > > Compass Components, Inc.
> > > 510-661-6666Â Office
> > > 510-656-0603Â Fax
> > > msantillan@<mailto:msantillan@>
> > > www.ccicms.com<http://www.ccicms.com/>
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of vacortes21
> > > Sent: Friday, June 08, 2012 10:24 AM
> > > I am using Method "JobEntry.ChangeJobProdProdQty"
> > > I am using the ttJobHead table in the email.
> > > thanks for your help with this.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ted Koch <tkoch77@<mailto:tkoch77@>> wrote:
> > > > What JobEntry Method are you using and what table are you trying to get the job number from that it doesnt show in the email?
> > > > From: vacortes21 <vcortes@<mailto:vcortes@>>
> > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> > > > Sent: Thursday, June 7, 2012 7:22 PM
> > > > Thankk You so much this works Great! :)
> > > > however I am having a problem with the email. I created the email in the post-processing directive "send e-mail synchronously based on the test template" and did a insert field Query to add the JobNum but it does not show up on the email.
> > > > any idea? am i doing something wronge?
> > > > thanks again for your help with this.
> > > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ted Koch <tkoch77@> wrote:
> > > > > I would do this through a BPM.
> > > > > Pre-processing Conditions:
> > > > > the jobhead.jobreleased field of the changed row is equal to the true expression
> > > > > and the ttjobhead.prodqty field has been change from any to any
> > > > > pre-processing actions:
> > > > > enable dependent post process directives
> > > > > Then create the email in a post-processing directive.
> > > > > Didnt have time to test, but that may work for you.
> > > > > Sent: Tuesday, June 5, 2012 3:54 PM
> > > > > Subject: [Vantage] Send e-mail on Job Prod Qty change
> > > > > Im am looking to create an email notification when a Job Prod Qty is changed after the job has been released.
> > > > > Has anyone done something similar? which way would be the best way to this and how?
> > > > > Thank you so much for your help.
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
> > > > > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > [Non-text portions of this message have been removed]
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
>Â From: vacortes21 <vcortes@...>
> >Â
Regards,
Miguel A. Santillan
ERP Administrator
510-661-6666 Office
510-656-0603 Fax
msantillan@...<mailto:msantillan@...>
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Ted Koch <tkoch77@...<mailto:tkoch77@...>> wrote:
> From: vacortes21 <vcortes@...<mailto:vcortes@...>>
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> Regards,
> Miguel A. Santillan
> ERP Administrator
> 510-661-6666 Office
> 510-656-0603 Fax
> Regards,
> Miguel A. Santillan
> ERP Administrator
> 510-656-0603Â Fax
> > Regards,
> > Miguel A. Santillan
> > ERP Administrator
> > 510-656-0603Â Fax
> > Regards,
> > Miguel A. Santillan
> > ERP Administrator
> > 510-656-0603Â Fax
