Hi All,
Its there a way to pass new parameters to a Crystal report from a built-in report?
I want to send a few parameters from the Job traveler to my crystal report.
Could someone point me in the right direction or if this could be done?
Regards,
Jose C Gomez
T: 904.469.1524 mobile
On Tue, Jan 20, 2015 at 4:01 PM, jaime.hdzm@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p></p><p><span>Hi All,</span></p><p><span><br></span></p><p><span><br></span></p><p>Its there a way to pass new parameters to a Crystal report from a built-in report?</p><p>I want to send a few parameters from the Job traveler to my crystal report.</p><p>Could someone point me in the right direction or if this could be done? </p><p><br></p><p>Regards,</p><p></p> </div> <div style="color:#fff;min-height:0;"></div>
I have added parameters right into the Crystal Report
The Crystal parameter sheet will pop up after the initial XML is generated.
Kind of funky but it works....
It helps with the “funky†to put a False report option in BAQ Report Designer and under the description say “Press Print Preview†or “Crystal Filters†to let the users know there are Crystal Filters also.
Sent: Wednesday, January 21, 2015 15:43
Subject: [Vantage] Re: Sent Parameters from a Built-in Report
In a few cases when I couldn't get the right filter on the report form...
This email and any attached files are confidential and intended solely for the intended recipient(s). If you are not the named recipient you should not read, distribute, copy or alter this email. Any views or opinions expressed in this email are those of the author and do not represent those of the Specialty Screw Corporation company. Warning: Although precautions have been taken to make sure no viruses are present in this email, the company cannot accept responsibility for any loss or damage that arise from the use of this email or attachments.
