Serial Matching
I am trying to do a serial matching of all the serial numbers contained in a job at the same time. I mean, there is a way to can select all the serial numbers that contain a Job at the same time to can do the serial match once to all the serial numbers contained in the Job selected? or there only way to do the serial match is one by one?
Luis P.
One by one unless you wrote some code to perform that logic. Personal opinion is that this would fall under a “medium complexity”.
I am assuming by your question that your job is to make QTY 1 of the top level item, and that you issued multiple serialized items to the job, and that you want to match all those serial numbers to the one top item? That seems like it could be automated, but as @Jason_Woods said, it would have some difficulty…
but if you have a job making more than one top level, I don’t know or understand HOW you would automate such a thing… the software is designed to handle doing something like a job for 10 computers, where you issue 10 serialized memory cards and 10 serialized computer chips, and 10 serialized video cards… the Matching allows you to specify which memory, computer chip, and video card went into each top level serial numbered computer.
What about in cases where we are issuing our own consecutive serial numbers for all the sub-components?
For a job with qty 500 with 500 SNs, having to match each top level SN to lower level material with the same SN is a terribly labor intensive process. Is there any way to automate the Serial Matching step at all? Assigning SNs and issuing material is straightforward, however Serial Matching is a no-go for usability. Would need to have someone spend hours clicking back and forth for a job of qty 500.
Scot - was this SN matching issue ever resolved?
