Serial numbers on Invoices
Do you know if there was an RMA created for the serialized part? We have had the problem in the past where a serialized part was returned and then later sold to another customer. Vantage then assigned the serial number to the new customer invoice and removed it from the old one.
David
--- In vantage@yahoogroups.com, "sgotschall" <sgotschall@...> wrote:
> Vantage 8.03.407a Progress
> We have an invoice that's a few months old where the original printed invoice shows the serial number but when we reprint it, the serial number is gone.
> The serial number is still in the system, it just doesn't show up on the invoice. A sample of other invoices do not have this problem, only one we found so far.
> It doesn't appear that the invoice tables store the serial number. It is a calculated field in the report definition, but I'm not sure where or how the information is pulled into the report.
> Anyone have any idea on how this could have happened? Its not a big deal, but if it happened once it can happen again and I would like to avoid it.
