Serial Tracking in Plant Config
I think if you have serialized parts on hand, then it is greyed out. I had to change early on in our testing and had to remove all of the serial numbers before I could enable.
Greg
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of scrausch2@...
Sent: Wednesday, April 02, 2014 4:46 PM
Subject: [Vantage] Serial Tracking in Plant Config
I am trying to enable lower level serial tracking on the Plant Config, but the dropdown boxed is grayed out. Any clue as to what would be preventing this from being changed?
Scott
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Scott
