In theory it should not cause any problems. In practice you may want to take a look at partitioning the applications into something akin to Parallels Virtuoso Containers so that no one of the servers can monopolize the single systems resources and so that you minimize the possibility of a single point of failure.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
On Mar 10, 2011, at 5:11 AM, michael.hutcheson@... wrote:
> If I had one server with Service Connect, SQL and IIS combined, would this cause problems?
> --- In vantage@yahoogroups.com, "Blake Clemens" <blake.clemens@...> wrote:
> > We have ours set up like this. But we can justify running SQL
> > independently because we also use it to run Sharepoint.
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > Delmarva Millwork Corporation
> > (800) 360-2364 x132
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of michael.hutcheson@...
> > Sent: Thursday, March 10, 2011 5:05 AM
> > Subject: [Vantage] Server configuration
> > Hello,
> > What is the best server setup when implenting Service Connect? We
> > currently have Vantage running on its own server with a Progress
> > backend. I was going to install Service Connect and SQL on another
> > server and leave it at that. However, I was reading the below setup is
> > recommended: This seems a little over kill though.
> > Recommended Server Configuration
> > * Server 1: Epicor Service Connect
> > * Server 2: Microsoft SQL Server
> > * Server 3: Microsoft IIS for Epicor Web services (Alternate: shared
> > with Server 1 or
> > other Epicor application server)
> > Does anybody else have service connect setup like the above?
> > Regards,
> > Michael
> > Vantage 8.03.406
