Server drive configuration
How many users are you supporting with this configuration?
_____
bw2868bond
Sent: Thursday, July 22, 2010 4:43 PM
Subject: [Vantage] Re: server drive configuration
Almost everybody on the group here will advocate the Raid 10 setup.
We use raid10 on production server
my test server has a raid 1 pair for server 2008R2 OS
I have a 4 drive raid 10 for the application files and work directory and a
14 drive raid 10 array for the databases - It sure is fun watching the raid
controller max out when restoring a backup from one array to the other :o)
"greg.middleton11" <greg.middleton@...> wrote:
> Working on a server configuration for E9.05 and Epicor is recommending a
RAID 10 configuration with a minimum of 6 drives. This would be for Progress
OpenEdge. Epicor says this will be critical to get the performance we want.
Can anybody verify that they are using this configuration or something
similar?
Working on a server configuration for E9.05 and Epicor is recommending a RAID 10 configuration with a minimum of 6 drives. This would be for Progress OpenEdge. Epicor says this will be critical to get the performance we want. Can anybody verify that they are using this configuration or something similar?
RAID 10 is a must, IMHO.
I normally setup 2 - 4 drive RAID10s and split that database across the
two but I can certainly see 6 drives delivering better performance.
Of greg.middleton11
Sent: Thursday, July 22, 2010 3:08 PM
Subject: [Vantage] server drive configuration
I have a 4 drive raid 10 for the application files and work directory and a 14 drive raid 10 array for the databases - It sure is fun watching the raid controller max out when restoring a backup from one array to the other :o)
--- In vantage@yahoogroups.com, "greg.middleton11" <greg.middleton@...> wrote:
