Hello!
I’ve created several BAQ reports recently - some from scratch others are modified copies of the BAQ with a new Report Style. All the reports utilize APR and I want to save them to a ProcessTask so that they are emailed on a schedule. I’m having trouble when trying to save the ProcessTask. Some times I have no issues but more often than not I get a Server Side Error. I can’t figure out if I’m doing something wrong in the BAQ or Report design that is causing the issue or if it is something else all together. I can run the BAQ and the report manually with no issues. I just can’t add them to a process set.
Appreciate any thoughts!
Server Side Exception
A server error occurred. Review the server event logs for details.
Error Detail
Correlation ID: aaa556ec-f723-41f7-8130-e675bb1f5fe1
Description: A server error occurred. Review the server event logs for details.
Program: Epicor.Ice.Server.Wcf.Core.dll
Method: ProvideFault
Line Number: 33
Column Number: 17
Server Trace Stack: at Epicor.Hosting.Wcf.ErrorHandler.ProvideFault(Exception error, MessageVersion version, Message& fault) in C:_Releases\ICE\ICE4.1.100.11\Source\Server\Hosting\Wcf\Ice.Server.Wcf.Core\Hosting\Wcf\ErrorHandler.cs:line 33
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideFault(Exception e, FaultConverter faultConverter, ErrorHandlerFaultInfo& faultInfo)
at System.ServiceModel.Dispatcher.ErrorBehavior.ProvideMessageFaultCore(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage8(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.ProcessError(Exception e)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener1.ReceiveItemAndVerifySecurityAsyncResult
2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.Runtime.InputQueue1.AsyncQueueReader.Set(Item item) at System.Runtime.InputQueue
1.EnqueueAndDispatch(Item item, Boolean canDispatchOnThisThread)
at System.Runtime.InputQueue1.EnqueueAndDispatch(T item, Action dequeuedCallback, Boolean canDispatchOnThisThread) at System.ServiceModel.Channels.SingletonChannelAcceptor
3.Enqueue(QueueItemType item, Action dequeuedCallback, Boolean canDispatchOnThisThread)
at System.ServiceModel.Channels.HttpPipeline.EnqueueMessageAsyncResult.CompleteParseAndEnqueue(IAsyncResult result)
at System.ServiceModel.Channels.HttpPipeline.EnqueueMessageAsyncResult.HandleParseIncomingMessage(IAsyncResult result)
at System.Runtime.AsyncResult.AsyncCompletionWrapperCallback(IAsyncResult result)
at System.ServiceModel.Channels.HttpInput.ParseMessageAsyncResult.OnRead(IAsyncResult result)
at System.Web.Hosting.AsyncResultBase.Complete(Int32 hresult, Boolean synchronous)
at System.Web.Hosting.PipelineRuntime.AsyncCompletionHandler(IntPtr rootedObjectsPointer, Int32 bytesCompleted, Int32 hresult, IntPtr pAsyncCompletionContext)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.Rpt.BAQReportImpl.SaveProcessTask(String maintProgram, BAQReportDataSet ds)
at Ice.Lib.Adapters.BAQReportAdapter.SaveProcessTask(String baqReportId)
at Ice.UI.Rpt.BAQReport.Transaction.adapterSaveProcessTask()
at Ice.Lib.Framework.EpiReportTransaction.SaveProcessTask()
