Server Hard drives for Epicor 9.05
Good DayNick:
APM - Advanced Print Module - best if on 32-bit. There waa
talk of a fix in 601A, but may be buggy.
Some people say Web-Portal, but most say it is OK on 64-bit.
len.hartka@...
Of Robinson, Nick
Sent: Thursday, October 21, 2010 9:04 AM
Subject: RE: [Vantage] Server Hard drives for Epicor 9.05
What modules still require 32 bit? Has to be the application server?
Behalf
Of Len Hartka
Sent: Tuesday, October 19, 2010 3:24 PM
Good Day:
Sun Is on M2K 7.0 SP 5 (Informix) but,
Going to: Epicor 9, 9.05.601A SQL (go live date is 12/1/10)
Below is what we used. 55-65 users - we think it will handle 75-80.
there were some minor changes.
Servers were Dell with two Nehalem Quad processors - faster then four
Quad of other type.
Even with all that, system is slow, but the problem is not the core
speed, but the Interface to the Workstation and the 'configuration' of
pages. MRP = 6 or 12 hours depending on if run with 3 MRP-Processes,
45-60 seconds for programs to open ( the first time each day), etc.
I wanted SSD's, but 18 months ago they did cost $50,000, but now I would
believe $4,000 to 8,000.
BUT, SSD's are only really fast I one direction ( read?) - the speed
differential is no where near the same for write.
To test, play with a USB ( same technology) - write much slower then
read. By the way, there are USB's that are 30% faster then most.
Spindles, Spindles, spindles - that is all we heard from everyone and
yes it is not for storage but for speed since each spindle can be
processing at once.
Watch out for 32 vs 64 bit - some modules still must be 32.
Also, watch out for OS - can limit how much memory you can USE ( no fit,
but use).
len.hartka@... <mailto:len.hartka%40sunautomation.com>
Apps Server - (2-146) RAID1-OS, OS
24G ( 2 -146) RAID1 , Epicor 9 Application
(1-146) hot spare
SQL - (2-73GB) Raid1, OS and SQL app
48G (4-73GB) Raid 10 Temp-db
(1-73) hot spare
Disc Array - (10-73GB) RAID10, Data-MDF
(12-73GB) RAID10, Log-LDF
(2-73GB) hot Spare
Misc app\Virtualized: (3 -300GB) RAID 5 1. Web Server w/4 cores, 8 gig
memory win 2008 64bit Enterprise
24G (1-300GB) hot spare 2. Crystal reports, APM, Mgnt Reporter w/2 cores
4 gig mem win 2003 32 bit Std ( Add SQL std??)
3. E Portal w/2 cores 4 gig mem win 2008 64 bit Enterprise ( Add SQL
std??)
Redundant Server: (3-300GB)- RAID5
24G (1-300GB) hot Spare
Behalf Of Michael Barry
Sent: Tuesday, October 19, 2010 3:30 PM
Subject: Re: [Vantage] Server Hard drives for Epicor 9.05
Thanks for making my point but where do you get your more money
equivalency? One of the fastest SSD's available is from Crucial and a
128 GB drive is $469. In your proposed 4 drive array the cost would be
$1876. Then there are the savings from reduced chassis, power supply,
thermal management, etc. In practical application you can build a 1U
server with a handful of SSD's for under $4000 that will absolutely blow
the doors off of a $15,000 mega chassis multi spindle monster.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
On Oct 19, 2010, at 11:16 AM, Jose Gomez wrote:
> I would respectfully disagree with Michael, the reason for 16 drives
> is not about storage its all about performance. RAID 10 with 16 drives
> would give you the best performance for you database unless u want to
> spend more money and get SSD's which would provide a huge performance
boost.
> Here is an example
> 16 SCSI Drive Raid 10: 1200-1600 IO/S
> 4 SSD Drives Raid 10: 50,000+ IO/S
> There is your performance ;-)
> Sincerely
> Jose C Gomez
> http://www.josecgomez.com
> On Tue, Oct 19, 2010 at 12:55 PM, Michael Barry <mbarry@...
<mailto:mbarry%40aspacia.com>
<mailto:mbarry%40aspacia.com> > wrote:
> > There are only two scenario where this recommendation isn't pure
lunacy.
> > First, your database would have to be absolutely enormous - on the
> > order of hundreds of gigabytes to require that much physical
> > storage. Second would be attempting to improve application
> > performance by striping the I/O across multiple spindles and/or
> > controllers. If you are really the former then you are talking way
> > beyond the average PC/server market and would need to be looking at
> > enterprise class hardware from IBM/SUN/HP/Fujitsu, etc because
> > sixteen drives worth of throughput will absolutely overwhelm a
> > typical PC/Server backplane. If it is for performance, then a
handful of strategically arrayed SSD's will blow the flotilla of
magnetic drives away.
> > Either way, your goofy appraisal seems spot on....
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > On Oct 19, 2010, at 7:43 AM, PLAMAN, DICK wrote:
> > > My "hardware requirements" documents specifies that the server
> > > should
> > have 16 SIXTEEN drives??
> > > This seems a little goofy to me.
> > > Is this correct? We have between 50 - 60 full users.
> > > thanks
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > must have already linked your email address to a yahoo id to enable
> > access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder and Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
This e-mail and any attachments may contain proprietary and/or
confidential information. If you are not the intended recipient, please
notify the sender immediately by reply e-mail or at 410-472-2900 and
then delete the message without using, disseminating, or copying this
message or any portion thereof. With e-mail communications you are urged
to protect against viruses.
The information in this email (and any attachments) is confidential. If
you are not the intended recipient, you must not use or disseminate the
information. If you have received this email in error, please
immediately notify me by "Reply" command and permanently delete the
original and any copies or printouts thereof. Although this email and
any attachments are believed to be free of any virus or other defect
that might affect any computer system into which it is received and
opened, it is the responsibility of the recipient to ensure that it is
virus free and no responsibility is accepted by Sparrows for any loss or
damage arising in any way from its use.
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
My "hardware requirements" documents specifies that the server should have 16 SIXTEEN drives??
thanks
There are only two scenario where this recommendation isn't pure lunacy. First, your database would have to be absolutely enormous - on the order of hundreds of gigabytes to require that much physical storage. Second would be attempting to improve application performance by striping the I/O across multiple spindles and/or controllers. If you are really the former then you are talking way beyond the average PC/server market and would need to be looking at enterprise class hardware from IBM/SUN/HP/Fujitsu, etc because sixteen drives worth of throughput will absolutely overwhelm a typical PC/Server backplane. If it is for performance, then a handful of strategically arrayed SSD's will blow the flotilla of magnetic drives away.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
> thanks
I would respectfully disagree with Michael, the reason for 16 drives is not
about storage its all about performance. RAID 10 with 16 drives would give
you the best performance for you database unless u want to spend more money
and get SSD's which would provide a huge performance boost.
Here is an example
Sincerely
Jose C Gomez
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> > thanks
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
Thanks for making my point but where do you get your more money equivalency? One of the fastest SSD's available is from Crucial and a 128 GB drive is $469. In your proposed 4 drive array the cost would be $1876. Then there are the savings from reduced chassis, power supply, thermal management, etc. In practical application you can build a 1U server with a handful of SSD's for under $4000 that will absolutely blow the doors off of a $15,000 mega chassis multi spindle monster.
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
> Here is an example
> Sincerely
> Jose C Gomez
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > > thanks
Good Day:
Below is what we used. 55-65 users - we think it will handle 75-80. there were some minor changes.
Servers were Dell with two Nehalem Quad processors - faster then four Quad of other type.
Even with all that, system is slow, but the problem is not the core speed, but the Interface to the Workstation and the 'configuration' of pages. MRP = 6 or 12 hours depending on if run with 3 MRP-Processes, 45-60 seconds for programs to open ( the first time each day), etc.
I wanted SSD's, but 18 months ago they did cost $50,000, but now I would believe $4,000 to 8,000.
BUT, SSD's are only really fast I one direction ( read?) - the speed differential is no where near the same for write.
To test, play with a USB ( same technology) - write much slower then read. By the way, there are USB's that are 30% faster then most.
Spindles, Spindles, spindles - that is all we heard from everyone and yes it is not for storage but for speed since each spindle can be processing at once.
Also, watch out for OS - can limit how much memory you can USE ( no fit, but use).
len.hartka@...
(1-146) hot spare
(1-73) hot spare
(2-73GB) hot Spare
Misc app\Virtualized: (3 -300GB) RAID 5 1. Web Server w/4 cores, 8 gig memory win 2008 64bit Enterprise
24G (1-300GB) hot spare 2. Crystal reports, APM, Mgnt Reporter w/2 cores 4 gig mem win 2003 32 bit Std ( Add SQL std??)
3. E Portal w/2 cores 4 gig mem win 2008 64 bit Enterprise ( Add SQL std??)
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Michael Barry
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
> spend more money and get SSD's which would provide a huge performance boost.
> Here is an example
> Sincerely
> Jose C Gomez
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > > should
> > > thanks
> > access. )
The 'limitations' of SSD write speed are mostly nullified by the nature of a
database workload. Although traditional drives can keep up (and occasionally
surpass) SSD in sequential write performance, databases loads are almost
exclusively composed of random read/write requests. Because of this, the
massive advantage in seek time causes the SSDs to provide far better
'real-world' performance. Also, the difference in read/write on modern SSDs
in nowhere near as dramatic as what you see in a common USB thumb drive. The
reasons are a bit beyond me, but I believe it has a lot to do with caching,
write leveling and more sophisticated firmware.
This is quickly becoming a moot point though, as the newer SSD are quickly
approaching (if they haven't already) the same sequential write performance
you see in high-end SCSI drives.
On Tue, Oct 19, 2010 at 4:23 PM, Len Hartka <len.hartka@...>wrote:
> Good Day:
> of other type.
> once.
> but use).
> len.hartka@... <len.hartka%40sunautomation.com>
> (1-146) hot spare
> (1-73) hot spare
> (2-73GB) hot Spare
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of Michael
> Barry
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Regards,
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> boost.
> > Here is an example
> > Sincerely
> > Jose C Gomez
> > On Tue, Oct 19, 2010 at 12:55 PM, Michael Barry <mbarry@...<mbarry%40aspacia.com>>
> lunacy.
> away.
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > > should
> > > > thanks
> > > access. )
> viruses.
Of Len Hartka
Good Day:
Quad of other type.
processing at once.
but use).
(1-146) hot spare
(1-73) hot spare
(2-73GB) hot Spare
std??)
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
boost.
> Here is an example
> Sincerely
> Jose C Gomez
lunacy.
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > > should
> > > thanks
> > access. )
The information in this email (and any attachments) is confidential. If you are not the intended recipient, you must not use or disseminate the information. If you have received this email in error, please immediately notify me by "Reply" command and permanently delete the original and any copies or printouts thereof. Although this email and any attachments are believed to be free of any virus or other defect that might affect any computer system into which it is received and opened, it is the responsibility of the recipient to ensure that it is virus free and no responsibility is accepted by Sparrows for any loss or damage arising in any way from its use.
To the best of my knowledge, none of the 'core' modules require 32-bit.
The documentation mentions an administrative console that requires 32-bit,
but I'm not sure what it is. I know both the 'Epicor Admin Console' and the
'Open Edge Explorer' function fine in 64-bit environments.
Perhaps some of the 3rd party software?
On Thu, Oct 21, 2010 at 9:03 AM, Robinson, Nick <
> Of Len Hartka
> Good Day:
> Quad of other type.
> processing at once.
> but use).
> len.hartka@... <len.hartka%40sunautomation.com> <mailto:
> len.hartka%40sunautomation.com <len.hartka%2540sunautomation.com>>
> (1-146) hot spare
> (1-73) hot spare
> (2-73GB) hot Spare
> std??)
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> <mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>>
> [mailto:vantage@yahoogroups.com <vantage%40yahoogroups.com> <mailto:
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>> ] On
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com> <mailto:
> Regards,
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> boost.
> > Here is an example
> > Sincerely
> > Jose C Gomez
> lunacy.
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > > should
> > > > thanks
> > > access. )
> way from its use.
Progress Explorer doesn't work in 64 Bit...or Vista/2008 and higher I
believe.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Of Waffqle Driggers
Sent: Thursday, October 21, 2010 9:36 AM
32-bit, but I'm not sure what it is. I know both the 'Epicor Admin
Console' and the 'Open Edge Explorer' function fine in 64-bit
environments.
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of Len
> Hartka
> Good Day:
> Sun Is on M2K 7.0 SP 5 (Informix) but, Going to: Epicor 9, 9.05.601A
> Quad of other type.
> processing at once.
> fit, but use).
> (1-146) hot spare
> (1-73) hot spare
> (2-73GB) hot Spare
> memory win 2008 64bit Enterprise 24G (1-300GB) hot spare 2. Crystal
> 4 gig mem win 2003 32 bit Std ( Add SQL std??) 3. E Portal w/2 cores 4
> std??)
> vantage%40yahoogroups.com <vantage%2540yahoogroups.com>> ] On Behalf
> Of Michael Barry
> Regards,
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> > drives
> > to spend more money and get SSD's which would provide a huge
> > performance
> boost.
> > Here is an example
> > Sincerely
> > Jose C Gomez
> lunacy.
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > > should
> > > > thanks
> > > enable access. )
Epicor has a registry edit that will get PE to work on 64-bit 2008 servers.
> believe.
> Of Waffqle Driggers
> environments.
> > Hartka
> > Good Day:
> > Quad of other type.
> > processing at once.
> > fit, but use).
> > (1-146) hot spare
> > (1-73) hot spare
> > (2-73GB) hot Spare
> > std??)
> > Of Michael Barry
> > Regards,
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > > drives
> > > performance
> > boost.
> > > Here is an example
> > > Sincerely
> > > Jose C Gomez
> > lunacy.
> > > > Michael
> > > > Michael Barry
> > > > Aspacia Systems Inc
> > > > 866.566.9600
> > > > 312.803.0730 fax
> > > > > should
> > > > > thanks
> > > > enable access. )
The new OpenEdge Explorer that replaces it works fine.
> --- In vantage@yahoogroups.com <vantage%40yahoogroups.com>, Joe Rojas
> > believe.
> > Of Waffqle Driggers
> > environments.
> > > From: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> > > Hartka
> > > To: vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> 40yahoogroups.com>
> > > Good Day:
> > > Quad of other type.
> > > processing at once.
> > > fit, but use).
> > > (1-146) hot spare
> > > (1-73) hot spare
> > > (2-73GB) hot Spare
> > > std??)
> > > [mailto:vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> > > Of Michael Barry
> > > Regards,
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > > drives
> > > > performance
> > > boost.
> > > > Here is an example
> > > > Sincerely
> > > > Jose C Gomez
> > > <mailto:mbarry%40aspacia.com <mbarry%2540aspacia.com> <mbarry%
> > > lunacy.
> > > > > Michael
> > > > > Michael Barry
> > > > > Aspacia Systems Inc
> > > > > 866.566.9600
> > > > > 312.803.0730 fax
> > > > > > should
> > > > > > thanks
> > > > > enable access. )
But can you create new databases and app servers with OpenEdge Explorer?
Of Waffqle Driggers
Sent: Thursday, October 21, 2010 9:57 AM
Subject: Re: [Vantage] Re: Server Hard drives for Epicor 9.05
servers.
> > I believe.
> > beautiful
> > not
> > Of Waffqle Driggers
32-bit.
> > environments.
> > On Thu, Oct 21, 2010 at 9:03 AM, Robinson, Nick < nick.robinson@...>
server?
> > > <vantage%
> > > Hartka
> 40yahoogroups.com>
> > > Good Day:
75-80.
> > > 'configuration' of
> > > MRP-Processes,
etc.
most.
> > > no fit, but use).
> > > Apps Server - (2-146) RAID1-OS, OS 24G ( 2 -146) RAID1 , Epicor 9
> > > Application
> > > (1-146) hot spare
> > > SQL - (2-73GB) Raid1, OS and SQL app 48G (4-73GB) Raid 10 Temp-db
> > > (1-73) hot spare
> > > (2-73GB) hot Spare
> > > gig
> > > cores 4
> > > std??)
> > > Redundant Server: (3-300GB)- RAID5 24G (1-300GB) hot Spare
> > > <vantage%
> > > <vantage%
> > > and a
> > > would be
spindle monster.
> > > Regards,
> > > Michael
> > > Michael Barry
> > > Aspacia Systems Inc
> > > 866.566.9600
> > > 312.803.0730 fax
> > > > drives
> > > > drives
> > > > want to spend more money and get SSD's which would provide a
> > > > huge performance
> > > boost.
> > > > Here is an example
> > > > Sincerely
> > > > Jose C Gomez
> > > > > pure
> > > lunacy.
> > > > > the
> > > > > talking way
> > > > > performance, then a
> > > > > Michael
> > > > > Michael Barry
> > > > > Aspacia Systems Inc
> > > > > 866.566.9600
> > > > > 312.803.0730 fax
> > > > > > server should
> > > > > > thanks
> > > > > to enable access. )
goto:
enable access.
> > > disseminating,
confidential.
> > > disseminate
> > access. )
All the options to do so are in the UI, but I haven't actually used them yet
so I can't verify that they work properly.
> jrojas@... <jrojas%40matsinc.com> | www.matsinc.com Ask us about
> of the company.
> Of Waffqle Driggers
> On Thu, Oct 21, 2010 at 9:54 AM, mattcald_73 <matt@...<matt%40kerusso.com>>
> servers.
> > --- In vantage@yahoogroups.com <vantage%40yahoogroups.com> <vantage%
> > > I believe.
> > > beautiful
> > > not
> > > Of Waffqle Driggers
> 40yahoogroups.com>
> 32-bit.
> > > environments.
> server?
> 40yahoogroups.com>
> > > > <vantage%
> > > > Hartka
> > 40yahoogroups.com>
> > > > Good Day:
> 75-80.
> > > > 'configuration' of
> > > > MRP-Processes,
> etc.
> most.
> > > > no fit, but use).
> > > > Application
> > > > (1-146) hot spare
> > > > (1-73) hot spare
> > > > (2-73GB) hot Spare
> > > > gig
> > > > cores 4
> > > > std??)
> 40yahoogroups.com>
> > > > <vantage%
> > > > [mailto:vantage@yahoogroups.com <vantage%40yahoogroups.com><vantage%
> 40yahoogroups.com>
> > > > <vantage%
> > > > and a
> > > > would be
> spindle monster.
> > > > Regards,
> > > > Michael
> > > > Michael Barry
> > > > Aspacia Systems Inc
> > > > 866.566.9600
> > > > 312.803.0730 fax
> > > > > drives
> > > > > drives
> > > > > huge performance
> > > > boost.
> > > > > Here is an example
> > > > > Sincerely
> > > > > Jose C Gomez
> > > > > > pure
> > > > lunacy.
> > > > > > the
> > > > > > talking way
> > > > > > performance, then a
> > > > > > Michael
> > > > > > Michael Barry
> > > > > > Aspacia Systems Inc
> > > > > > 866.566.9600
> > > > > > 312.803.0730 fax
> > > > > > > server should
> > > > > > > thanks
> > > > > > to enable access. )
> goto:
> enable access.
> > > > disseminating,
> confidential.
> > > > disseminate
> > > access. )
