Yes, I've been waiting for corporate IT to add our new server to the
domain, but it hasn't happened. I need to get moving before the old server
goes off line forever so it looks like I'll be adding 50 users manually...
*sigh*
Best Regards,
Gary Grenier (IT Manager)
SML Bell
Tel #: (+1)-207-784-2961 x245
Fax #: (+1)-207-784-9838
"Ari Footlik"
<ari@...
m> To
Sent by: <vantage@yahoogroups.com>
vantage@yahoogrou cc
ps.com
Subject
RE: [Vantage] Server Issue
2009-02-18 10:23
AM
Please respond to
vantage@yahoogrou
ps.com
If you're using "Workgroup" and not a domain, make sure you've added a
local-user to the new server for each desktop user, and the usernames
and passwords you set up on the server must match, exactly, the ones on
the desktops. If you have 5 users, this is no big deal. If you have 50
users, you should really consider moving to a domain-based
configuration...
The "Append DNS Suffix" option shouldn't have any affect on your
problem.
--Ari
Of garygrenier@...
Sent: Wednesday, February 18, 2009 9:25 AM
Subject: Re: [Vantage] Server Issue
There is no domain at this time. Our old server and all workstations
(and
the new server) are all members of the WORKGROUP workgroup, which is why
I
was thinking there might be some default setting not allowing
workstations
to map to shares. Of course, you all might be onto something that I'm
not
understanding yet.
I checked the TCP/IP settings on the new and old servers. The only thing
different between the two, other than the static IP was that the old one
was set to "append DNS suffix". I changed the other to match.
Best Regards,
SML Bell
"Ned"
<TechnoBabbly@gma
il.com> To
Sent by: <vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> >
ps.com
Subject
2009-02-18 09:51
AM
Please respond to
vantage@yahoogrou
ps.com
If the server is not a member server in the domain, has a static IP
address
and does not have the proper DNS(or sometimes WINS) entries then it
won't be
able to find your domain controller in order to be registered, and have
all
proper permissions propagated then you can run into problems like this.
Behalf
It is intended only for the use of the named recipient. Any use or
disclosure of this email is strictly prohibited, if you are not the
intended recipient. In case you have received this email in error,
please notify us immediately and then delete this email.
To help reduce unnecessary paper wastage, we would request that you do
not print this email unless it is really necessary - thank you.
Confidentiality Notice: The information in this email is confidential. It is intended only for the use of the named recipient. Any use or disclosure of this email is strictly prohibited, if you are not the intended recipient. In case you have received this email in error, please notify us immediately and then delete this email.
To help reduce unnecessary paper wastage, we would request that you do not print this email unless it is really necessary - thank you.
*sigh*
Best Regards,
SML Bell
"Ari Footlik"
<ari@...
m> To
ps.com
Subject
2009-02-18 10:23
AM
Please respond to
vantage@yahoogrou
ps.com
configuration...
problem.
--Ari
Of garygrenier@...
(and
I
workstations
not
understanding yet.
Best Regards,
SML Bell
"Ned"
<TechnoBabbly@gma
il.com> To
ps.com
Subject
2009-02-18 09:51
AM
Please respond to
vantage@yahoogrou
ps.com
address
won't be
all
> From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
> Ofnew
> garygrenier@... <mailto:garygrenier%40sml.com>
> Sent: Wednesday, February 18, 2009 9:22 AM
> Subject: [Vantage] Server Issue
> Hi all,
> Well, I've finally moved to where I'm trying to set up the client on
> another machine. This is probably very easy, but I haven't set up a
> server in years. I can't access the share, EPIC51, or any share, froma
> workstation. "Network path could not be found." I'm sure it's just aIt
> network access setting of some kind. Anyone know right off the top of
> their heads?
> Thanks in advance.
> Best Regards,
> SML Bell
> isdisclosure of
> this email is strictly prohibited, if you are not the intendedrecipient.
> Inimmediately
> andnot
> print this email unless it is really necessary - thank you.It
> is intended only for the use of the named recipient. Any use orplease
> notify us immediately and then delete this email.not
> print this email unless it is really necessary - thank you.)
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builderand
> Crystal Reports and other 'goodies', please goto:<http://groups.yahoo.com/group/vantage/files/.>
> (2) To search through old msg's goto:<http://groups.yahoo.com/group/vantage/messages>
> (3) To view links to Vendors that provide Vantage services goto:<http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
