Server Log - commLink database disconnect
<!-- #ygrps-yiv-521314962 _filtered #ygrps-yiv-521314962 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-521314962 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-521314962 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-521314962 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} _filtered #ygrps-yiv-521314962 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-521314962 #ygrps-yiv-521314962 p.ygrps-yiv-521314962MsoNormal, #ygrps-yiv-521314962 li.ygrps-yiv-521314962MsoNormal, #ygrps-yiv-521314962 div.ygrps-yiv-521314962MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-521314962 a:link, #ygrps-yiv-521314962 span.ygrps-yiv-521314962MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-521314962 a:visited, #ygrps-yiv-521314962 span.ygrps-yiv-521314962MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-521314962 p.ygrps-yiv-521314962MsoPlainText, #ygrps-yiv-521314962 li.ygrps-yiv-521314962MsoPlainText, #ygrps-yiv-521314962 div.ygrps-yiv-521314962MsoPlainText {
margin:0in;
font-size:11.0pt;
font-family:“Calibri”, “sans-serif”;}
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-521314962 code
font-family:“Courier New”;}
#ygrps-yiv-521314962 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-521314962 tt
#ygrps-yiv-521314962 span.ygrps-yiv-521314962HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-521314962 p.ygrps-yiv-521314962attach, #ygrps-yiv-521314962 li.ygrps-yiv-521314962attach, #ygrps-yiv-521314962 div.ygrps-yiv-521314962attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-521314962 p.ygrps-yiv-521314962bold, #ygrps-yiv-521314962 li.ygrps-yiv-521314962bold, #ygrps-yiv-521314962 div.ygrps-yiv-521314962bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-521314962 p.ygrps-yiv-521314962green, #ygrps-yiv-521314962 li.ygrps-yiv-521314962green, #ygrps-yiv-521314962 div.ygrps-yiv-521314962green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-521314962 p.ygrps-yiv-521314962replbq, #ygrps-yiv-521314962 li.ygrps-yiv-521314962replbq, #ygrps-yiv-521314962 div.ygrps-yiv-521314962replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-521314962 p.ygrps-yiv-521314962ad, #ygrps-yiv-521314962 li.ygrps-yiv-521314962ad, #ygrps-yiv-521314962 div.ygrps-yiv-521314962ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-521314962 p.ygrps-yiv-521314962underline, #ygrps-yiv-521314962 li.ygrps-yiv-521314962underline, #ygrps-yiv-521314962 div.ygrps-yiv-521314962underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-521314962 span.ygrps-yiv-521314962yshortcuts
#ygrps-yiv-521314962 p.ygrps-yiv-521314962ad1, #ygrps-yiv-521314962 li.ygrps-yiv-521314962ad1, #ygrps-yiv-521314962 div.ygrps-yiv-521314962ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-521314962 p.ygrps-yiv-521314962ad2, #ygrps-yiv-521314962 li.ygrps-yiv-521314962ad2, #ygrps-yiv-521314962 div.ygrps-yiv-521314962ad2
margin-right:0in;
margin-bottom:7.5pt;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-521314962 p.ygrps-yiv-521314962underline1, #ygrps-yiv-521314962 li.ygrps-yiv-521314962underline1, #ygrps-yiv-521314962 div.ygrps-yiv-521314962underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-521314962 span.ygrps-yiv-521314962yshortcuts1
font-family:“Verdana”, “sans-serif”;
font-weight:bold;}
#ygrps-yiv-521314962 span.ygrps-yiv-521314962yshortcuts2
font-weight:normal;}
#ygrps-yiv-521314962 span.ygrps-yiv-521314962EmailStyle34
color:#1F497D;}
#ygrps-yiv-521314962 span.ygrps-yiv-521314962PlainTextChar
#ygrps-yiv-521314962 .ygrps-yiv-521314962MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-521314962 div.ygrps-yiv-521314962WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-521314962 ol
{margin-bottom:0in;}
#ygrps-yiv-521314962 ul
Has anyone received the commLink server error message below where the database gets disconnected and they have to reboot the appservers? What could be causing this server error to help troubleshoot?
[15/12/23@14:06:12.982-0600] P-005076 T-000208 1 AS – (Procedure: ‘commLinkTest as/deactivate.p’ Line:66) Unable to communicate with the database. (Disconnecting database Epicor905 due to server communication failure (14959)).
We had that and it was from a flaky nic. Epicor support had me use a cross over cable direct between the app server and sql server to rule out the switch and then we found the card issue. Replaced the card, but kept the crossover and it was fine from then on.
Sometimes it is just the one process the P-005076 in your example and you can just kill that process id and not have to restart the server.
I restart on the weekend to start fresh each week.
Sent: Monday, June 06, 2016 10:31 AM
Subject: [Vantage] Server Log - commLink database disconnect
[15/12/23@14:06:12.982-0600] P-005076 T-000208 1 AS -- (Procedure: 'commLinkTest as/deactivate.p' Line:66) Unable to communicate with the database. (Disconnecting database Epicor905 due to server communication failure (14959)).
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
I crosschecked the event log with the app server log and found the nic was showing a disconnect and reconnect just before the appserver issue.
Sent: Monday, June 06, 2016 5:25 PM
Subject: RE: [Vantage] Server Log - commLink database disconnect
How did you determine it was a card issue?  I believe our admin team reviewed the nic and ruled this out as a possible cause.
Sent: Monday, June 06, 2016 3:14 PM
Do you have a nic Team? If it's teamed you need to unteam the nic cards.
If you don't have a team what is the manufacturer of your nic card? Broadcom is usually the culprit behind these kind of errors. I suggest going with an intel nic card.
Jonathan Lang
I.T Manager
Database Engineer
Broadcom has known issues with databases. I don't use them for any server. Switch out the nic and your woes will go away. I suggest going with an intel nic.
Jonathan Lang
I.T Manager
Database Engineer
On Tuesday, June 7, 2016 10:37 AM, "'Chang, Chia' cchang@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1690159058yiv0214924736ygrp-text">
  <div></div><div class="ygrps-yiv-1690159058yiv0214924736WordSection1"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Below is the physical host’s NIC information.</span></div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:11.0pt;color:#1F497D;">Broadcom NetXtreme II 10 Gb Ethernet BCM57810</span></div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:11.0pt;color:#1F497D;"> &nbsp;</span></div><div class="ygrps-yiv-1690159058yiv0214924736yqt4284558388" id="ygrps-yiv-1690159058yiv0214924736yqt93959"><div><div style="border-top:solid #B5C4DF 1.0pt;padding:3.0pt 0in 0in 0in;"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><b><span style="font-size:10.0pt;">From:</span></b><span style="font-size:10.0pt;"> vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] <br clear="none"><b>Sent:</b> Tuesday, June 07, 2016 9:43 AM<br clear="none"><b>To:</b> vantage@yahoogroups.com<br clear="none"><b>Subject:</b> Re: [Vantage] Server Log - commLink database disconnect</span></div></div></div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"> &nbsp;</div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal">&nbsp; </div><div id="ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg"><div id="ygrps-yiv-1690159058yiv0214924736ygrp-msg"><div id="ygrps-yiv-1690159058yiv0214924736ygrp-text"><div><div id="ygrps-yiv-1690159058yiv0214924736"><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_9647"><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_9646"><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7521"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal" style="background:white;"><span style="color:black;">Do you have a nic Team? If it&#39;s teamed you need to unteam the nic cards.&nbsp;</span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7521"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal" style="background:white;"><span style="color:black;"> &nbsp;</span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7521"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal" style="background:white;"><span style="color:black;">If you don&#39;t have a team what is the manufacturer of your nic card? Broadcom is usually the culprit behind these kind of errors. I suggest going with an intel nic card.&nbsp;</span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7499"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal" style="background:white;"><span style="color:black;">&nbsp;</span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7494"><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7522"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal" style="background:white;"><b><span style="color:blue;background:white;">Jonathan Lang</span></b><span style="color:black;"></span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7612"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><b><span style="font-size:10.0pt;color:black;">I.T Manager</span></b><span style="font-size:10.0pt;color:black;"></span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7498"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:10.0pt;color:black;">Database Engineer</span></div></div><div id="ygrps-yiv-1690159058yiv0214924736yui_3_16_0_ym19_1_1465305579379_7493"><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="font-size:10.0pt;color:black;"> &nbsp;</span></div></div></div></div></div></div></div></div><div><div class="ygrps-yiv-1690159058yiv0214924736MsoNormal"><span style="color:white;"></span></div></div></div></div></div></div>
</div>
<div class="ygrps-yiv-1690159058yiv0214924736yqt4284558388" id="ygrps-yiv-1690159058yiv0214924736yqt53360"><div style="color:#fff;min-height:0;"></div></div>
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736 -- #ygrps-yiv-1690159058yiv0214924736ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp #ygrps-yiv-1690159058yiv0214924736hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp #ygrps-yiv-1690159058yiv0214924736ads {
margin-bottom:10px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp .ygrps-yiv-1690159058yiv0214924736ad {
padding:0 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp .ygrps-yiv-1690159058yiv0214924736ad p {
margin:0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mkp .ygrps-yiv-1690159058yiv0214924736ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ygrp-lc {
font-family:Arial;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ygrp-lc #ygrps-yiv-1690159058yiv0214924736hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ygrp-lc .ygrps-yiv-1690159058yiv0214924736ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity span {
font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity span span {
color:#ff7900;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736activity span .ygrps-yiv-1690159058yiv0214924736underline {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;min-width:400px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736attach div a {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736attach img {
border:none;padding-right:5px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736attach label a {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736bold a {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 dd.ygrps-yiv-1690159058yiv0214924736last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 dd.ygrps-yiv-1690159058yiv0214924736last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 dd.ygrps-yiv-1690159058yiv0214924736last p span.ygrps-yiv-1690159058yiv0214924736yshortcuts {
margin-right:0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736attach-table div div a {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736attach-table {
min-width:400px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736file-title a, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736file-title a:active, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736file-title a:hover, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736file-title a:visited {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736photo-title a, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736photo-title a:active, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736photo-title a:hover, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div.ygrps-yiv-1690159058yiv0214924736photo-title a:visited {
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 div#ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg #ygrps-yiv-1690159058yiv0214924736ygrp-msg p a span.ygrps-yiv-1690159058yiv0214924736yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736green {
color:#628c2a;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 o {
font-size:0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736photos div {
float:left;min-width:72px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736photos div div {
border:1px solid #666666;min-height:62px;overflow:hidden;min-width:62px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;min-width:64px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736reco-category {
font-size:77%;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736reco-desc {
font-size:77%;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 .ygrps-yiv-1690159058yiv0214924736replbq {
margin:4px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg select, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 input, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg pre, #ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 code {
font:115% monospace;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-mlmsg #ygrps-yiv-1690159058yiv0214924736logo {
padding-bottom:10px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-msg p#ygrps-yiv-1690159058yiv0214924736attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-reco #ygrps-yiv-1690159058yiv0214924736reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-sponsor #ygrps-yiv-1690159058yiv0214924736ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-text {
font-family:Georgia;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-text tt {
font-size:120%;}
#ygrps-yiv-1690159058 #ygrps-yiv-1690159058yiv0214924736 #ygrps-yiv-1690159058yiv0214924736ygrp-vital ul li:last-child {
border-right:none !important;}
Broadcom’s are just fine with the latest drivers I’m running them on hyperv with no issues. @cchang make sure VMQ is disabled at the VM level and the NIC driver level. Also make sure you have the latest drivers. That card in particular the new drivers should come with a management interface GUI based I believe. If you have a NIC team setup also make sure your management port is not rolled into that. You want one physical just for management out of the vmnic. Also if you are using NIC teaming and a crossover cable you are going to have a bad time sometimes the traffic would go over the crossover and sometimes it might go through the switch.
Joshua Giese
Technology Solutions : CXO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
Sent: Tuesday, June 7, 2016 10:56
Subject: Re: [Vantage] Server Log - commLink database disconnect
Jonathan Lang
I.T Manager
Database Engineer
Sent: Tuesday, June 07, 2016 9:43 AM
Jonathan Lang
I.T Manager
Database Engineer
