Server Log Error - FileLookup.P
I have a colleague that is getting this error in his log files. He's on
8.03.305L Progress. He seems to believe this started occurring after he
applied the "L" patch.
Has anyone seen this before? This seems like it's pointing to a common
file that all Vantage installs have but I don't know what would be
causing this.
There are hundreds of these entries.
Thank you in advance.
[09/11/02@13:25:51.812-0500] P-005856 T-005860 1 AS -- (Procedure:
'\\server1\epicor\mfgsys803\server\ud\test\filelookup.p' Line:23) Entry
0 is outside the range of list 375,0.009,0.012,0.375. (560)
[09/11/02@13:26:36.406-0500] P-005856 T-005860 1 AS -- (Procedure:
0 is outside the range of list 500,0.01,0.015,0.5. (560)
[09/11/02@13:28:36.562-0500] P-005856 T-005860 1 AS -- (Procedure:
0 is outside the range of list 875,0.014,0.022,0.875. (560)
[09/11/02@13:35:02.812-0500] P-004552 T-002588 1 AS -- (Procedure:
[09/11/02@13:42:37.453-0500] P-005856 T-005860 1 AS -- (Procedure:
9 is outside the range of list ,,,0,0.188,0.25,0.375,0.5. (560)
[09/11/02@13:42:37.468-0500] P-005856 T-005860 1 AS -- (Procedure:
11 is outside the range of list ,,,0,0.188,0.25,0.375,0.5. (560)
