Correct..but..you got me thinkin in that direction thanks! So, I changed the path, resubmitted it, smashed the original, and restarted my app server.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
<http://www.dsmfg.com/>
(Click the logo to view our site) <http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Wednesday, November 18, 2009 2:36 PM
Subject: Re: [Vantage] Re: server log error
That took me a while to get straight in my head. If you look at a task under General Operations, you aren't really looking at the task as it may be set up in the system agent, you are just looking at the last settings used or default settings, but not the settings of the scheduled task. As you found out, you have to "crack open" the task under the system agent to see the settings for the scheduled task, and while you can't change the settings of a scheduled task, you can change the settings and save it as a new scheduled task and then delete the original task.
From: Rob Bucek <rbucek@... <mailto:rbucek%40dsmfg.com> >
Sent: Wed, November 18, 2009 3:26:25 PM
Subject: RE: [Vantage] Re: server log error
AHA!!
Thank you all! I do remember that when we back up, we blow away the
task agent and recreate it for reasons along these lines...but. .when you
look at the tasks etc it shows the proper path...until I cracked open
view task parameters under actions in the system agent maintenance. .and
there it was...
Rob Bucek
FAX: (715)284-4084
<http://www.dsmfg. com/>
(Click the logo to view our site) <http://www.dsmfg. com/>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Rob Bucek
Sent: Wednesday, November 18, 2009 2:16 PM
To: vantage@yahoogroups .com
This was in fact a back up from our live...
Rob Bucek
FAX: (715)284-4084
From: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
[mailto:vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of bw2868bond
Sent: Wednesday, November 18, 2009 1:02 PM
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Subject: [Vantage] Re: server log error
To further complicate things.....
if you restored a backup onto a test server - the log settings were
stored in the db and when you started up the test machine it happily
read the stored info and went on it's way
somehow you need to stop the processes, delete them from the startup
schedule and re create on the proper drive/path
--- In vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
<mailto:vantage% 40yahoogroups. com> ,
"Brian W. Spolarich " <bspolarich@ ...> wrote:
suspect that one of your three appservers, probably the ProcessServer,
has this directory defined incorrectly. If you change it and restart the
appserver all should be well. I'd check all three just to make sure, but
I suspect your main appserver wouldn't work if it didn't have a valid
Working Directory since a bunch of temp-table data is cached there (I
*think* that's true).
Behalf Of Rob Bucek
http://groups. yahoo.com/ group/vantage/ files/.
<http://groups. yahoo.com/ group/vantage/ files/>
Rob Bucek
FAX: (715)284-4084
AHA!!
there it was...
Rob Bucek
FAX: (715)284-4084
Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
Behalf
Of bw2868bond
>Directory" as defined in your AppServer config in Progress Explorer. I
> The base directory that these files are written to is the "Working
>/ Picometrix
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix
> bspolarich@. .. ~ 734-864-5618 ~ www.advancedphotoni x.com<mailto:vantage% 40yahoogroups. com>
> -----Original Message-----
Behalf Of Rob Bucek
> Sent: Wednesday, November 18, 2009 1:32 PM<mailto:vantage% 40yahoogroups. com>
> Subject: [Vantage] server log errorhave already linked your email address to a yahoo id to enable access. )
> In my test server I am getting the following error...
> [09/11/17@17: 09:03.635- 0600] P-003800 T-000212 1 AS -- (Procedure:
> 'sendToLog-Email si/sim100.p' Line:4902) ** Unable to open file:
> e:/epicor/mfgwrk803 /GlobalAlertsEma il.log. Errno=13. (98)
> There is no e:/ drive on this server, I looked in the global
> alerts/email process form and its set to D:/ drive... anywhere else I
> should be looking?
> Rob Bucek
> FAX: (715)284-4084
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builderand Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto:http://groups. yahoo.com/ group/vantage/ messages
> (3) To view links to Vendors that provide Vantage services goto:http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
