Server Performance
Dan,
You may be well served to try the usual suspects. Have you truncated the BI
file and/or performed a dump and load?
Regards,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
<http://www.aspacia.com/> http://www.aspacia.com/
vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dan
Ernst
Sent: Friday, February 02, 2007 6:37 AM
Subject: [Vantage] Re: Server Performance
Thanks Mark
I will try tuning the database settings. Could my biggest problem be
the size of the database, we are at 14gb right now.
Dan Ernst
Correct Craft, Inc.
"marko9280" <molbrantz@...> wrote:
> I posted a couple of documents under "Files" "Admin" on V8 database
> tuning and performance that maybe helpful.
> Good Luck!
> Mark
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Dan
Ernst" <dernst@> wrote:
> > Is anyone else running Vantage 6.1 and Vantage 8.03 on the same
> server?
> > I am using a Dell 2800 with dual 3.4ghz and 4gb ram and the
> performance
> > is terrible ever since we installed 8.03. I have already changed
the
> > port number for OpenEdge 10.0B to 20555, it was using the same as
> > Progress 91D. The only thing on this server is Vantage, any
> suggestions?
> > Thanks
> > Dan Ernst
> > Correct Craft, Inc.
Is anyone else running Vantage 6.1 and Vantage 8.03 on the same server?
I am using a Dell 2800 with dual 3.4ghz and 4gb ram and the performance
is terrible ever since we installed 8.03. I have already changed the
Progress 91D. The only thing on this server is Vantage, any suggestions?
Dan Ernst
Correct Craft, Inc.
Good Luck!
Mark
server?
performance
suggestions?
> Thanks
> Dan Ernst
> Correct Craft, Inc.
Thanks Mark
Dan Ernst
Correct Craft, Inc.
> Good Luck!
> Mark
> server?
> performance
the
> suggestions?
> > Thanks
> > Dan Ernst
> > Correct Craft, Inc.
