Vantage is a 32bit application, however there are many appserver
processes running on the server, each one can address up to 4Gb of ram
which would allow it to take advantage of the additional memory. Also,
even if Vantage didn't use the additional memory the OS will use it,
allowing Vantage to have access to the full 4Gb, and will use additional
memory as disk cache.
Brian Johnson -- Epi-Center <http://epi-ctr.com>
Systems Consulting/Development Manager | direct: 413-531-2859
>[Non-text portions of this message have been removed]
> Pretty much everything they said is true. You need 64 bit server to
> take advantage of anything above 4 gb ram. There is no upgrade path
> from the 32 bit to 64 bit, so basically you have to start from
> scratch. Vantage is only a 32 bit program, so unless you have other
> applications running on the server, going to 64 bit and increasing the
> RAM won't help much. Also be aware that not all 32 bit programs will
> run on 64 bit Windows, so you have to check the compatibility of every
> piece of 32 bit software you want to run on 64 bit Windows. We run
> Vantage on a 64 bit server, but we started out that way.
> From: Blake Clemens <blake.clemens@...
> <mailto:blake.clemens%40d-m-c.com>>
> Sent: Fri, November 13, 2009 4:18:06 PM
> Subject: [Vantage] Server RAM Upgrade
> I want to upgrade our 32-bit (Sp2) Windows Standard Server's RAM from 4
> Gig to 12 Gig. What do I have to do and how will it affect Vantage?
> Dell is telling me that I have to go to 64-Bit. I want to get
> Enterprise Edition. But Dell is also telling me that when I do the
> install of Enterprise it will wipe out Vantage and any other program
> installed on the server. Has anyone had any experience with this?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> Delmarva Millwork Corporation
> (800) 360-2364 x132
