Server / SQL server 2012 Express (Answered)
Well that makes sense, I had assumed you were using the SQL 2012 on Windows
2008 not in Windows 2012.
Windows 2012 is not certified for anything that I was aware of.
brenda mohr
Sent: Monday, July 22, 2013 9:20 AM
Subject: [Vantage] Server / SQL server 2012 Express (Answered)
Per Epicor:
According with our Progress documentation, this broker error is related to
an incompatibility with the progress driver for SQL databases in Windows
Server 2012, according to progress only Progress databases are allowed to
work on WS2012. And according with our HW requirements guide (which can be
downloaded from the Epic web) your client should have a windows server 2008
environement.
Brenda
brenda mohr
Sent: Tuesday, July 16, 2013 1:40 PM
Subject: RE: [Vantage] Server / SQL server 2012 Express
YES - TCP/IP Configured
NO - Anti-Virus
Server Log:
[13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- Logging level greater
than 1 must be specified either for ASPlumbing or for all types by using
-logginglevel. (11072) [13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS
-- Logging level greater than 1 must be specified either for DB.Connects or
for all types by using -logginglevel. (11072) [13/07/15@21:19:22.972-0400]
P-003440 T-004952 1 AS -- Logging level set to = 1
[13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- No entry types are
activated [13/07/15@21:19:23.065-0400] P-003244 T-005084 1 AS -- Logging
level greater than 1 must be specified either for ASPlumbing or for all
types by using -logginglevel. (11072) [13/07/15@21:19:23.066-0400] P-003244
T-005084 1 AS -- Logging level greater than 1 must be specified either for
DB.Connects or for all types by using -logginglevel. (11072)
[13/07/15@21:19:23.066-0400] P-003244 T-005084 1 AS -- Logging level set to
= 1 [13/07/15@21:19:23.066-0400] P-003244 T-005084 1 AS -- No entry types
are activated [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- Logging
types by using -logginglevel. (11072) [13/07/15@21:19:23.325-0400] P-005872
T-005868 1 AS -- Logging level greater than 1 must be specified either for
[13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- Logging level set to
= 1 [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- No entry types
are activated [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- Logging
types by using -logginglevel. (11072) [13/07/15@21:19:23.610-0400] P-005888
T-005884 1 AS -- Logging level greater than 1 must be specified either for
[13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- Logging level set to
= 1 [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- No entry types
are activated [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- Logging
types by using -logginglevel. (11072) [13/07/15@21:19:23.742-0400] P-004876
T-001180 1 AS -- Logging level greater than 1 must be specified either for
[13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- Logging level set to
= 1 [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- No entry types
are activated
Brenda
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Mark Wonsil
Sent: Tuesday, July 16, 2013 1:12 PM
Subject: Re: [Vantage] Server / SQL server 2012 Express
Do you have TCP/IP configured for the instance? Running Anti-Virus on that
machine?
Mark W.
On Tue, Jul 16, 2013 at 12:02 PM, brenda mohr
<brenda@...<mailto:brenda%40humtown.com>> wrote:
> [13/07/15@21:19:27.253-0400] P-004904 T-S-0005 1 UB ----------
> IOException reading message from server : java.io.EOFException: pipe
> to server broken (8117) [13/07/15@21:19:27.254-0400] P-004904 T-S-0005
> 2 UB Basic ERROR: cannot start server. (8100)
> Brenda
> Behalf Of Ned
> Sent: Tuesday, July 16, 2013 11:11 AM
> I assume that is the error from the Broker log, what is the error in
> the server log? That usually tells more than the other error.
> From:
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40y
ahoogroups.com> [mailto:
> ge%40yahoogroups.com>] On Behalf Of brenda mohr
> Sent: Tuesday, July 16, 2013 8:47 AM
> To:
> Is anyone running these successfully?
> How do you get around the error: AppServer Pipe To Server Broken.
> Not a port conflict, added sql user accts, setup all local policies,
> checked mfgsys files.....
> Brenda
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access.
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/
> group/vantage/files/>< http://groups.yahoo.com/group/vantage/files/>
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/
vantage/files/>
Per Epicor:
According with our Progress documentation, this broker error is related to an incompatibility with the progress driver for SQL databases in Windows Server 2012, according to progress only Progress databases are allowed to work on WS2012. And according with our HW requirements guide (which can be downloaded from the Epic web) your client should have a windows server 2008 environement.
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of brenda mohr
NO - Anti-Virus
Server Log:
[13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- Logging level greater than 1 must be specified either for ASPlumbing or for all types by using -logginglevel. (11072) [13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- Logging level greater than 1 must be specified either for DB.Connects or for all types by using -logginglevel. (11072) [13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- Logging level set to = 1 [13/07/15@21:19:22.972-0400] P-003440 T-004952 1 AS -- No entry types are activated [13/07/15@21:19:23.065-0400] P-003244 T-005084 1 AS -- Logging level greater than 1 must be specified either for ASPlumbing or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.066-0400] P-003244 T-005084 1 AS -- Logging level greater than 1 must be specified either for DB.Connects or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.066-0400] P-003244 T-005084 1 AS -- Logging level set to = 1 [13/07/15@21:19:23.066-0400] P-003244 T-005084 1 AS -- No entry types are activated [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- Logging level greater than 1 must be specified either for ASPlumbing or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- Logging level greater than 1 must be specified either for DB.Connects or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- Logging level set to = 1 [13/07/15@21:19:23.325-0400] P-005872 T-005868 1 AS -- No entry types are activated [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- Logging level greater than 1 must be specified either for ASPlumbing or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- Logging level greater than 1 must be specified either for DB.Connects or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- Logging level set to = 1 [13/07/15@21:19:23.610-0400] P-005888 T-005884 1 AS -- No entry types are activated [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- Logging level greater than 1 must be specified either for ASPlumbing or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- Logging level greater than 1 must be specified either for DB.Connects or for all types by using -logginglevel. (11072) [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- Logging level set to = 1 [13/07/15@21:19:23.742-0400] P-004876 T-001180 1 AS -- No entry types are activated
Brenda
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark Wonsil
Do you have TCP/IP configured for the instance? Running Anti-Virus on that machine?
Mark W.
On Tue, Jul 16, 2013 at 12:02 PM, brenda mohr <brenda@...<mailto:brenda%40humtown.com>> wrote:
> Brenda
> Behalf Of Ned
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
> Of brenda mohr
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Brenda
> http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/><
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
