Service Connect 8.2 - AR Adjustment Service - 8.03.404A
Anyone have any experience with Service Connect and the AR Adjustment
service?? I am trying to build workflows that will allow us to do
adjustments on a large scale. When I get to the step where it is
supposed to do the update, I get the error below. Does anyone know what
that means??
Method not supported in this object.;
Client proxy error
Original exception: System.Web.Services.Protocols.SoapException
Code:http://schemas.xmlsoap.org/soap/envelope/:Server
Actor:
Detail: <detail> at
Epicor.Mfg.Proxy.ARAdjustmentImpl.GetNewInvcHeadAdj(ARAdjustmentDataSet
ds)
at Epicor.Mfg.WS.Adapters.ARAdjustmentBaseAdapter.Update(XmlNode
ARAdjustmentData)</detail>
Matt Caldwell
Technical Support Analyst
KERUSSO
P.O. Box 32
Berryville, AR 72616
Phone: 800-424-0943 Ext. 231 or 870-480-4530
Fax: 870-423-3568
Web Site: http://www.kerusso.com
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
