I have an XML file that I am using as my input schema. When I enter input schema on the conversion process it is not giving me an option for the "Root Entity" an therefore I can not do the configuration that I need to do. Has anyone seen this before? Is there something missing from the XML file? Did I do something wrong when using the schema utility when I created the schema? (Schema created using anyxml2xml).
Any help would be greatly appreciated.
Michelle de la Vega
Business Applications Manager
Cold Jet, LLC
455 Wards Corner Road
Loveland, Ohio 45140
513-716-6400 (direct)
513-382-3281 (cell)
513-831-1209 (fax)
www.coldjet.com<http://www.coldjet.com>
[cid:image001.jpg@...2A9500]
Michelle de la Vega
Cold Jet, LLC
513-382-3281 (cell)
513-831-1209 (fax)
