Service Connect - Choice.... yes or no?
Thanks Ed. That worked!
Blake Clemens
DMC
Of Ed Garbowski
Sent: Monday, April 20, 2009 12:10 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Service Connect - Choice.... yes or no?
Check that the 'Admit Value' is set to 'true' on one and 'false' on the
other rule in your XPATH expression.
Ed
Behalf Of Blake Clemens
Sent: Monday, April 20, 2009 11:02 AM
Subject: [Vantage] Service Connect - Choice.... yes or no?
I need some guidance on configuring a Choice in Service Connect. It's
fairly straight forward. If the Service Connect update succeeds then
YES... if Service Connect update fails then NO. The problem I'm having
is that no matter the outcome the workflow wants to follow the NO side
of the choice. How do I correctly program the choice to have the
workflow follow the correct path?
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
***Privileged & Confidential***
This email, together with any attachments, is intended for the named
recipient(s) only and may contain privileged and confidential
information. If received in error, please inform the sender as quickly
as possible and delete this email and any copies. If not an intended
recipient of this email, you must not copy, distribute or rely on it,
and any form of disclosure, modification, distribution and/or
publication of this email is prohibited.
Unless stated otherwise, this email represents only the views of the
sender and not the views of Delmarva Millwork Corporation.
The information contained in this message is intended solely for the
individual to whom it is specifically and originally addressed. This
message and its contents may contain confidential or privileged
information. If you are not the intended recipient, you are hereby
notified that any disclosure or distribution, or taking any action in
reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software
viruses, but we advise you to carry out your own virus checks on any
attachment to this message. We cannot accept liability for any loss or
damage caused by software viruses.
This message (including any attachments) is intended only for
the use of the individual or entity to which it is addressed and
may contain information that is non-public, proprietary,
privileged, confidential, and exempt from disclosure under
applicable law or may constitute as attorney work product.
If you are not the intended recipient, you are hereby notified
that any use, dissemination, distribution, or copying of this
communication is strictly prohibited. If you have received this
communication in error, notify us immediately by telephone and
(i) destroy this message if a facsimile or (ii) delete this message
immediately if this is an electronic communication.
Thank you.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Check that the 'Admit Value' is set to 'true' on one and 'false' on the other rule in your XPATH expression.
Ed
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
The information contained in this message is intended solely for the individual to whom it is specifically and originally addressed. This message and its contents may contain confidential or privileged information. If you are not the intended recipient, you are hereby notified that any disclosure or distribution, or taking any action in reliance on the contents of this information, is strictly prohibited.
We have taken precautions to minimize the risk of transmitting software viruses, but we advise you to carry out your own virus checks on any attachment to this message. We cannot accept liability for any loss or damage caused by software viruses.
Thank you.
