Service Connect - Completing Tasks
Daniel,
Be sure you are retrieving the correct task record before updating. This is usually done with a Get By ID request followed by an update. There are very few instances where I have been able to update an existing record without first retrieving it. That appears to be what you are attempting to do. I say this because of the ForceEmptyNode on key2 and key3. Those fields should be updated from the existing record, i.e. drug from the request method to the update method in the workflow. Also, as someone else noted, the "True" should be "true" as nothing else will work, however, that does not sound like the error you are getting.
----- Original Message -----
Sent: Thursday, September 18, 2008 6:15 AM
Subject: RE: [Vantage] Re: Service Connect - Completing Tasks
Yes, I'm using the RowMod = U. I am using the Task.Update BO method. Below
are the fields that I am setting.
Company = '03'
RelatedToFile = 'HDCase'
Key1 = '143'
Key2 = ForceEmptyNode
Key3 = ForceEmptyNode
TaskSeqNum = 10
TaskDescription = 'Revised'
SalesRepCode = 'NA'
Complete = True
WorkflowComplete = True
RowMod = 'U'
Daniel
_____
Cathlene Fishman
Sent: Wednesday, September 17, 2008 1:56 PM
Subject: [Vantage] Re: Service Connect - Completing Tasks
Daniel, do you have the RowMod = U ... ?
What BO.Method are you using?
I am trying to write a Service Connect workflow to mark certain tasks in
vantage as complete. I used tracing to find what BO are used but when I
follow those same steps in Service Connect it says that I can't use Update
method because the task already exists and the key fields need to be unique.
Has anyone used service connect or webservces to update tasks? If so, can
you give me any ideas to what I am doing wrong here? Thank,
Daniel
This is difficult to troubleshoot without actually seeing it. It could
have something to do with your mapping of fields within the workflow?
Maybe you need to create a container to pull through your work flow?
Of Daniel Laidig
Sent: Wednesday, September 17, 2008 12:25 PM
Subject: [Vantage] Service Connect - Completing Tasks
Update
unique.
can
Daniel
Company = '03'
Key1 = '143'
TaskSeqNum = 10
SalesRepCode = 'NA'
Complete = True
RowMod = 'U'
Daniel
_____
Cathlene Fishman
Not sure if this will help you or not, but to mark or unmark check boxes
in service connect, you have to pass "true" or "false". All lowercase,
or else nothing happens. "True", "TRUE", "False", or "FALSE" will not
work.
Of Daniel Laidig
Below
Company = '03'
Key1 = '143'
TaskSeqNum = 10
SalesRepCode = 'NA'
Complete = True
RowMod = 'U'
Daniel
_____
Behalf Of
Cathlene Fishman
