Service Connect Condition
Woo hoo! I just guessed on that one... J
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Daniel Laidig
Sent: Saturday, February 28, 2009 9:52 AM
Subject: RE: [Vantage] Service Connect Condition
thanks, that did the trick.
--- On Fri, 2/27/09, Brian W. Spolarich <bspolarich@...
Date: Friday, February 27, 2009, 4:32 PM
How about this approach? Use a conditional functoid as you suggest,
setting its default condition to Number01 (e.g.
/msg/req/dta/ GetByIDResponse/ result/PartDataS et/PartSubs/ Number01) -
just link it on the left to the default value if the checkbox isn't
checked.
Add an alternative whose condition expression is Checkbox01 (e.g.
/msg:msg/msg: req/msg:dta/ ext_GetByIDRespo nse:GetByIDRespo
nse/ext_GetByID
Response:result/ PartDataSet/ Part/Checkbox01) and whose value
expression
is Number02 (e.g.
nse/ext_GetByID
Response:result/ PartDataSet/ Part/Number02) . Map the result of that
expression to your target field.
I think that will do what you want.
Your mileage may vary.
Picometrix
bspolarich@advanced photonix. com ~ 734-864-5618 ~
www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Daniel Laidig
Sent: Friday, February 27, 2009 2:10 PM
To: vantage@yahoogroups .com
Subject: [Vantage] Service Connect Condition
I wrote a SC workflow that I need to have number01 be mapped to another
field if checkbox01=true otherwise I need number02 to be mapped to that
field. I am not really sure if a condition functoid in service connect
can
do what I want or not. I was hoping to be able to do this in my mapping
process and not using the condition statement in the main workflow
designer.
Does anyone have any suggestions on how I would tackle this? Thanks,
Daniel
field. I am not really sure if a condition functoid in service connect can
process and not using the condition statement in the main workflow designer.
Daniel
Well, if you don't want to do it in the XML mapper of the conversion,
them have a choice activity feed 2 different conversions depending on
outcome of testing the checkbox value
--- In vantage@yahoogroups.com, "Daniel Laidig" <daniellaidig@...>
another
that
connect can
mapping
designer.
> Daniel
/msg/req/dta/GetByIDResponse/result/PartDataSet/PartSubs/Number01) -
checked.
/msg:msg/msg:req/msg:dta/ext_GetByIDResponse:GetByIDResponse/ext_GetByID
Response:result/PartDataSet/Part/Checkbox01) and whose value expression
is Number02 (e.g.
Response:result/PartDataSet/Part/Number02). Map the result of that
Picometrix
Of Daniel Laidig
can
designer.
Daniel
checked.
/msg:msg/msg: req/msg:dta/ ext_GetByIDRespo nse:GetByIDRespo nse/ext_GetByID
Response:result/ PartDataSet/ Part/Checkbox01) and whose value expression
is Number02 (e.g.
Picometrix
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Daniel Laidig
can
designer.
Daniel
