I would do a choice (similar in structure to condition), use an = operator, tie your date node to the top, leave the bottom one blank (should show you "" - double quotes) path the data one way if it's not null and do your conversion, path it the other way and do something else.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of carl.heeder
Sent: Wednesday, May 16, 2012 2:28 PM
Subject: [Vantage] Re: Service Connect Date Conversion and Null values
I;ve also used the Conditional to test if ithe input field is blank. But how can I feed a Null value if the condition of the input field is blank?
Is it ? like 4GL or NULL (reserved word) or something else??
Rob Bucek
FAX: (715)284-4084
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "carl.heeder" <carl.heeder@...> wrote:
> I have an input field in a csv file that is either a date or a blank field. If it is not blank, I want to convert it to a date value and store it in a date field. If it is blank, I don;t want to store anything.
> I know how to do the string to date conversion but what do I use to make the decision about the blank?
