I need to pick some brains about a request. If I build a Service Connect Solution, I know when my SC solution fails to create a record, an error will appear in the Error log. The challenge is, my users don’t want to check the log in the SC Admin console, they want it as a report.
Can you build a report from this log? My first thought was to make the workflow pass the errors to an Epicor UDTable and have the report hit that UDTable to show the errors, but if there’s a way the report can go straight to the SC error log i’d like to do that instead as it sounds more streamlined to me. I’m pretty sure making SC build records in a UDTable is the only way to go for this, but I wanted to see what the group has to say.
Make error checking a part of your SC workflow,
Node -> Call Epicor DLL -> Check Error -> IF Error -> Send Email / Create UD Record etc…-> Otherwise -> Next Node… etc.
