Service Connect help
The easiest way to know if a field has something in it is to use the string
length functoid.
_____
bw2868bond
Sent: Monday, April 28, 2008 11:06 AM
Subject: [Vantage] Re: Service Connect help
I would use a conditional functoid from the special functoids tab.
default value = false
alternate value = true - condition expression would then be built in
the xpath builder using a string contains functoid with the email
address field as first argument and the 'at' sign as the second
argument.
bw
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Matt
Caldwell" <matt@...> wrote:
> I am not sure what Functoid to use to do this. Here is what I need
to
> do:
> When an email address exists in my import, I need to set the
NotifyFlag
> and QuantumView flag to true. I am not exactly sure how to do
this..
> Anyone have any ideas on how to accomplish this without adding
fields to
> my import..
> Matt Caldwell
> Technical Support Analyst
> KERUSSO
> P.O. Box 32
> Berryville, AR 72616
> Phone: 800-424-0943 Ext. 231
> Fax: 870-423-3568
> Web Site: http://www.kerusso <http://www.kerusso.com> com
> CONFIDENTIALITY STATEMENT:
> This message, from Kerusso Inc., contains information
> which is privileged and confidential and is solely for the use of
> the intended recipient. If you are not the intended recipient, be
> aware that any review, disclosure, copying, distribution, or use
> of the contents of this message is strictly prohibited. If you have
> received this in error, please destroy it and notify us immediately
> at: 800-424-0943
I am not sure what Functoid to use to do this. Here is what I need to
do:
When an email address exists in my import, I need to set the NotifyFlag
and QuantumView flag to true. I am not exactly sure how to do this..
Anyone have any ideas on how to accomplish this without adding fields to
my import..
Matt Caldwell
KERUSSO
P.O. Box 32
Fax: 870-423-3568
Web Site: http://www.kerusso.com
at: 800-424-0943
argument.
bw
to
> do:
NotifyFlag
this..
fields to
> my import..
> Matt Caldwell
> KERUSSO
> P.O. Box 32
> Fax: 870-423-3568
> at: 800-424-0943
