Service Connect - Inherited Objects Not Holding Values
Folks,
Still working with Service Connect. I’ve discovered that the inherited Process Variables in my sub-workflows are not holding their values from the parent workflow, even though the variables themselves appear in the XML mapping of every conversion element. Any ideas on what I’m doing wrong? The inherited Extension containers are working just fine, and the sub-workflows are cycling perfectly based on the data received from the parent workflow.
Correction - NO inherited objects are holding their values in the sub-workflows. No process variables, no data containers.
I found the problem. The Pass msg:usr section box in the general properties of the sub-workflow action on the parent workflow got unchecked.
