Service Connect not registered error
This is a DNS change. If you're in an Active Directory environment
then you're running DNS internally already so just create a CNAME record
in DNS that points to your Service Connect server.
Alternatively you can add an entry to
c:\windows\system32\drivers\etc\hosts to do it.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@... ~ 734-864-5618 ~
www.advancedphotonix.com
Of Charlie Wilson
Sent: Monday, January 12, 2009 10:29 AM
Subject: [Vantage] Re: Service Connect not registered error
Yes this is the first time.
Where is this setting kept so I can change scshost to the actual name
of the server?
~Charlie
"bw2868bond" <bwalker@...> wrote:
> Is the the first time you are trying to use the admin console?
> Do you have 'scshost' set up as host in your DNS Server? If not add
> an entry to your 'hosts' file
"Charlie Wilson" <foamdesigncsw@>
> wrote:
> > All,
> > When I open SC admin console and expand Connectivity I get an error
> message
> > that states "http://scshost is not registered. Service Connect will
> not
> > function Properly."
> > What is causing this issue and how do I resolve it?
> > ~Charlie
All,
When I open SC admin console and expand Connectivity I get an error message
that states "http://scshost is not registered. Service Connect will not
function Properly."
~Charlie
--- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@...>
wrote:
> All,
message
not
> function Properly."
> ~Charlie
of the server?
~Charlie
> --- In vantage@yahoogroups.com, "Charlie Wilson" <foamdesigncsw@>
> wrote:
> > All,
> message
> not
> > function Properly."
> > ~Charlie
