Service Connect: Parsing DateTimes
You need a "T" in there to denote the beginning of the Time segment. Thus "YYYY-MM-DDThh:mm:ss" is your format and gets you something that looks like "2009-08-04T15:07:35" as output. The formats for these things in Service Connect are XML Schema formats, which are a touch different than standard programming language and database formats many are used to.
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Can one use the dateTimeFromString() functoid to actually parse a
> DateTime in SC?
> I can parse a date (e.g. "MM-DD-YYYY") easily enough, but if I try to
> specific a format string such as "MM-DD-YYYY hh:mm:ss" the parser blows
> up and says:
> <SrcFile>Conversion.cpp</SrcFile>
> <SrcLine>240</SrcLine>
> </Error>
> <Error>
> <Type>COM</Type>
> <Code>0x80004005</Code>
> <Descr>Failed to parse date: Failed to parse format string: Format
> string has odd characters.</Descr>
> <Source>msxml4.dll</Source>
> </Error>
> </ErrHistory>
> The SC docs say this, and omit any notion of Time in a dateTime which
> seems, well, rather stupid. What am I missing?
> -bws
> Interpretation of Format String by parseDateTime Functoid
> The parseDateTime functoid interprets the specified string according to
> the format string, specified as the second parameter. The parseDateTime
> functoid uses the following rules, when interpreting the specified
> string:
> * Interpretation of date format string parts:
> Format string part
> Interpretation
> YY
> Year, short form.
> For example, 83 or 07.
> YYYY
> Year, long form.
> For example, 1983 or 2007.
> M
> Month, short form. If the month consists of two digits, both digits are
> displayed.
> For example, 5 for May or 11 for November.
> MM
> Month, long form (single digit values have a leading zero).
> For example, 05 for May or 11 for November.
> D
> Day, short form. If the day consists of two digits, both digits are
> displayed.
> For example, 5 or 22.
> DD
> Day, long form (single digit values have a leading zero).
> For example, 05 or 22.
> * Note: All format string parts (year, month and day) are
> required. A format string with missing part(s), such as dd-mm, cannot be
> used.
> * Interpretation of separators:
> The format string includes separator characters. The set of separator
> characters is limited to "/", "-" and ".".
> The separators are required, as a format string without separators may
> not be correctly interpreted.
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@...
> <mailto:bspolarich@...> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com>
DateTime in SC?
up and says:
</Error>
<Error>
<Type>COM</Type>
</Error>
</ErrHistory>
-bws
string:
Format string part
Interpretation
YY
Year, short form.
YYYY
Year, long form.
M
displayed.
MM
D
displayed.
DD
used.
Picometrix
bspolarich@...
