Service Connect Question - Get Value Based on another Value
Bummer, I was afraid of that. Without being able to cycle through each address, it will be difficult.
--Matt
--- In vantage@yahoogroups.com, "thedemondamian" <sheath@...> wrote:
> Karen and Matt,
> I set it up the way you were suggesting; without a functoid. I linked Address1 of my incoming document to OTSAddress1 on the OrderHed. Then I set a condition on the link to AddressTypeCode = "ST". The conversion still grabbed the first Address1 line in the list of addresses.
> I think it is like Rob is saying. The structure of the document does not allow the conversion to iterate through the addresses.
> I have a document I will send with some screen shots.
> --- In vantage@yahoogroups.com, "mattcald_73" <matt@> wrote:
> > You might try to right-click on the address nodes on the right side where you are linking them to, and "edit the condition". Add an "=" operator functoid, and set the condition where AddressTypeCode equal to "ST".
> > --- In vantage@yahoogroups.com, "thedemondamian" <sheath@> wrote:
> > > That is how I have it set up now. I am using a conditional functoid. My default value is empty and my alternative value is set to Address1. The condition for the alternative value is "where AddressTypeCode = ST". It still grabs the address1 value from the first address in the data.
> > > --- In vantage@yahoogroups.com, Karen Schoenung <kschoenung@> wrote:
> > > > You can probably use a condition on your link to address type code = "ST"
> > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of thedemondamian
> > > > Sent: Tuesday, April 16, 2013 4:03 PM
> > > > To: vantage@yahoogroups.com
> > > > Subject: [Vantage] Service Connect Question - Get Value Based on another Value
> > > > I have an xml file which I will post at the end. The xml file has a bank of Address nodes. None of the nodes have a unique value by which I can select the inner values.
> > > > In the xml below, I need to select the address information for the address that has the AddressTypeCode of "ST".
> > > > I have tried several different functoids, but cannot get the results I am looking for. It always ends up selecting the first address in the set.
> > > > Here is the xml:
> > > > <PurchaseOrder>
> > > > <Header>
> > > > <OrderHeader>
> > > > <CustomerId>2361</CustomerId>
> > > > <TradingPartnerId>9J6ALL</TradingPartnerId>
> > > > <PurchaseOrderNumber>TEST-EDI</PurchaseOrderNumber>
> > > > </OrderHeader>
> > > > <Date>
> > > > <DateTimeQualifier1>010</DateTimeQualifier1>
> > > > <Date1>2013-01-06</Date1>
> > > > </Date>
> > > > <Address>
> > > > <AddressTypeCode>BT</AddressTypeCode>
> > > > <AddressName>Brian Sten</AddressName>
> > > > <Address1>19 Not The Rd</Address1>
> > > > <City>GREEN BAY</City>
> > > > <State>WI</State>
> > > > <PostalCode>54311</PostalCode>
> > > > <Country>USA</Country>
> > > > <ContactPhone>1234567890</ContactPhone>
> > > > </Address>
> > > > <Address>
> > > > <AddressTypeCode>ST</AddressTypeCode>
> > > > <Address1>1987 This Blvd</Address1>
> > > > <Address2>Test Suite</Address2>
> > > > <State>WI</State>
> > > > <ContactPhone>0987654321</ContactPhone>
> > > > </Address>
> > > > <Address>
> > > > <AddressTypeCode>SO</AddressTypeCode>
> > > > <LocationCodeQualifier>93</LocationCodeQualifier>
> > > > <AddressLocationNumber>8119</AddressLocationNumber>
> > > > </Address>
> > > > <Address>
> > > > <AddressTypeCode>PO</AddressTypeCode>
> > > > <AddressName>Home</AddressName>
> > > > </Address>
> > > > <Reference>
> > > > <ReferenceQual>X9</ReferenceQual>
> > > > <ReferenceID>235907452</ReferenceID>
> > > > </Reference>
> > > > <Reference>
> > > > <ReferenceQual>SD</ReferenceQual>
> > > > <ReferenceID>8119</ReferenceID>
> > > > </Reference>
> > > > </Header>
> > > > <LineItems>
> > > > <LineItem>
> > > > <OrderLine>
> > > > <LineSequenceNumber>01</LineSequenceNumber>
> > > > <BuyerPartNumber>202461863</BuyerPartNumber>
> > > > <VendorPartNumber>20070411</VendorPartNumber>
> > > > <ConsumerPackageCode>094428264335</ConsumerPackageCode>
> > > > <PartNumberQualifier1>SK</PartNumberQualifier1>
> > > > <PartNumber1>477200</PartNumber1>
> > > > <PartDescription1>Remote Control</PartDescription1>
> > > > <OrderQty>1</OrderQty>
> > > > <OrderQtyUOM>EA</OrderQtyUOM>
> > > > <UnitPrice>170</UnitPrice>
> > > > <UnitPriceBasis>TE</UnitPriceBasis>
> > > > </OrderLine>
> > > > <Date>
> > > > <DateTimeQualifier1>038</DateTimeQualifier1>
> > > > </Date>
> > > > <Miscellaneous>
> > > > <Qualifier1>TD5</Qualifier1>
> > > > <Description1>UNSP_CG</Description1>
> > > > <Qualifier2>05</Qualifier2>
> > > > </Miscellaneous>
> > > > </LineItem>
> > > > <LineItem>
> > > > <OrderLine>
> > > > <BuyerPartNumber>202570542</BuyerPartNumber>
> > > > <VendorPartNumber>20020107</VendorPartNumber>
> > > > <ConsumerPackageCode>094428260993</ConsumerPackageCode>
> > > > <PartDescription1>Timer</PartDescription1>
> > > > <UnitPrice>45</UnitPrice>
> > > > </OrderLine>
> > > > <Date>
> > > > </Date>
> > > > <Miscellaneous>
> > > > </Miscellaneous>
> > > > </LineItem>
> > > > </LineItems>
> > > > <Summary>
> > > > <TotalLineItemNumber>1</TotalLineItemNumber>
> > > > </Summary>
> > > > </PurchaseOrder>
> > > > [Non-text portions of this message have been removed]
Here is the xml:
<PurchaseOrder>
<Header>
<OrderHeader>
</OrderHeader>
<Date>
</Date>
<Address>
<State>WI</State>
</Address>
<Address>
<State>WI</State>
</Address>
<Address>
</Address>
<Address>
</Address>
<Reference>
</Reference>
<Reference>
</Reference>
</Header>
<LineItems>
<LineItem>
<OrderLine>
</OrderLine>
<Date>
</Date>
<Miscellaneous>
</Miscellaneous>
</LineItem>
<LineItem>
<OrderLine>
</OrderLine>
<Date>
</Date>
<Miscellaneous>
</Miscellaneous>
</LineItem>
</LineItems>
<Summary>
</Summary>
</PurchaseOrder>
Here is the xml:
<PurchaseOrder>
<Header>
<OrderHeader>
</OrderHeader>
<Date>
</Date>
<Address>
<State>WI</State>
</Address>
<Address>
<State>WI</State>
</Address>
<Address>
</Address>
<Address>
</Address>
<Reference>
</Reference>
<Reference>
</Reference>
</Header>
<LineItems>
<LineItem>
<OrderLine>
</OrderLine>
<Date>
</Date>
<Miscellaneous>
</Miscellaneous>
</LineItem>
<LineItem>
<OrderLine>
</OrderLine>
<Date>
</Date>
<Miscellaneous>
</Miscellaneous>
</LineItem>
</LineItems>
<Summary>
</Summary>
</PurchaseOrder>
> Here is the xml:
> <PurchaseOrder>
> <Header>
> <OrderHeader>
> </OrderHeader>
> <Date>
> </Date>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> </Address>
> <Address>
> </Address>
> <Reference>
> </Reference>
> <Reference>
> </Reference>
> </Header>
> <LineItems>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> </LineItems>
> <Summary>
> </Summary>
> </PurchaseOrder>
Could we see screen shots of your functoid setup? Shoot them offline, I don't know if the number of address sets for you is a constant but I don't think it will just cycle through them and look for a condition (unless they are structured in a way you could move them into a sub), you would have to link each and every one and test for a condition...
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
Sent: Wednesday, April 17, 2013 7:46 AM
Subject: [Vantage] Re: Service Connect Question - Get Value Based on another Value
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of thedemondamian
> Here is the xml:
> <PurchaseOrder>
> <Header>
> <OrderHeader>
> </OrderHeader>
> <Date>
> </Date>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> </Address>
> <Address>
> </Address>
> <Reference>
> </Reference>
> <Reference>
> </Reference>
> </Header>
> <LineItems>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> </LineItems>
> <Summary>
> </Summary>
> </PurchaseOrder>
Reply via web post<http://groups.yahoo.com/group/vantage/post;_ylc=X3oDMTJwbHFxNDJyBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAMxMTk5MjgEc2VjA2Z0cgRzbGsDcnBseQRzdGltZQMxMzY2MjAyNzky?act=reply&messageNum=119928>
Reply to sender <mailto:sheath@...?subject=Re%3A%20Service%20Connect%20Question%20-%20Get%20Value%20Based%20on%20another%20Value>
Reply to group <mailto:vantage@yahoogroups.com?subject=Re%3A%20Service%20Connect%20Question%20-%20Get%20Value%20Based%20on%20another%20Value>
Start a New Topic<http://groups.yahoo.com/group/vantage/post;_ylc=X3oDMTJjZ2QwOGNwBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzEzNjYyMDI3OTI->
Messages in this topic<http://groups.yahoo.com/group/vantage/message/119901;_ylc=X3oDMTM2aWZobmJrBF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRtc2dJZAMxMTk5MjgEc2VjA2Z0cgRzbGsDdnRwYwRzdGltZQMxMzY2MjAyNzkyBHRwY0lkAzExOTkwMQ--> (3)
Recent Activity:
Visit Your Group<http://groups.yahoo.com/group/vantage;_ylc=X3oDMTJjZHY0bGI3BF9TAzk3MzU5NzE0BGdycElkAzIwMzY5BGdycHNwSWQDMTcwNTAwNzE4MQRzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzEzNjYyMDI3OTI->
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/>
No functiod - at least the way I am picturing this...You click on the LINK that is the line drawn from the left to the right and right click on the right side of the link to choose edit condition...Then you setup your condition that your left data address type code = "ST"? I will send some pictures direct to your email...
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Karen Schoenung <kschoenung@...<mailto:kschoenung@...>> wrote:
> Here is the xml:
> <PurchaseOrder>
> <Header>
> <OrderHeader>
> </OrderHeader>
> <Date>
> </Date>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> <State>WI</State>
> </Address>
> <Address>
> </Address>
> <Address>
> </Address>
> <Reference>
> </Reference>
> <Reference>
> </Reference>
> </Header>
> <LineItems>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> <LineItem>
> <OrderLine>
> </OrderLine>
> <Date>
> </Date>
> <Miscellaneous>
> </Miscellaneous>
> </LineItem>
> </LineItems>
> <Summary>
> </Summary>
> </PurchaseOrder>
> > Here is the xml:
> > <PurchaseOrder>
> > <Header>
> > <OrderHeader>
> > </OrderHeader>
> > <Date>
> > </Date>
> > <Address>
> > <State>WI</State>
> > </Address>
> > <Address>
> > <State>WI</State>
> > </Address>
> > <Address>
> > </Address>
> > <Address>
> > </Address>
> > <Reference>
> > </Reference>
> > <Reference>
> > </Reference>
> > </Header>
> > <LineItems>
> > <LineItem>
> > <OrderLine>
> > </OrderLine>
> > <Date>
> > </Date>
> > <Miscellaneous>
> > </Miscellaneous>
> > </LineItem>
> > <LineItem>
> > <OrderLine>
> > </OrderLine>
> > <Date>
> > </Date>
> > <Miscellaneous>
> > </Miscellaneous>
> > </LineItem>
> > </LineItems>
> > <Summary>
> > </Summary>
> > </PurchaseOrder>
Karen and Matt,
> > > Here is the xml:
> > > <PurchaseOrder>
> > > <Header>
> > > <OrderHeader>
> > > </OrderHeader>
> > > <Date>
> > > </Date>
> > > <Address>
> > > <State>WI</State>
> > > </Address>
> > > <Address>
> > > <State>WI</State>
> > > </Address>
> > > <Address>
> > > </Address>
> > > <Address>
> > > </Address>
> > > <Reference>
> > > </Reference>
> > > <Reference>
> > > </Reference>
> > > </Header>
> > > <LineItems>
> > > <LineItem>
> > > <OrderLine>
> > > </OrderLine>
> > > <Date>
> > > </Date>
> > > <Miscellaneous>
> > > </Miscellaneous>
> > > </LineItem>
> > > <LineItem>
> > > <OrderLine>
> > > </OrderLine>
> > > <Date>
> > > </Date>
> > > <Miscellaneous>
> > > </Miscellaneous>
> > > </LineItem>
> > > </LineItems>
> > > <Summary>
> > > </Summary>
> > > </PurchaseOrder>
