Service connect question
Hi,
Just to jump on the thread. We are looking to use Service Connect
with Vantage and Non-epicor products. Does anybody have any
experience of this?
--- In vantage@yahoogroups.com, "Waffqle Driggers" <waffqle@...>
wrote:
> Scratch that, I've found some problems. When you're creating
workflows, you
> can't specify the port number on a conversion. Probably a show
stopper.
> On 9/19/07, Waffqle Driggers <waffqle@...> wrote:
> > I had to do the same thing recently. You should just be able to
go into
> > IIS Manager and change the port. I don't know if this
configuration has
> > Epicor's blessing (if you call support they may just tell you to
put it back
> > on port 80). I've just started testing service connect a few
weeks ago, but
> > I've not run into any problems yet.
> > On 9/10/07, cdaveg <cdaveg@...> wrote:
> > > I installed Service Connect on a computer, only to discover
that I
> > > already had a web device running on port 80. I can access the
scshost
> > > at port 8080. Is there a way that I can reset Service connect
to use
> > > the 8080 port number instead of port 80?
> > > Dave
I installed Service Connect on a computer, only to discover that I
already had a web device running on port 80. I can access the scshost
at port 8080. Is there a way that I can reset Service connect to use
Dave
I had to do the same thing recently. You should just be able to go into IIS
Manager and change the port. I don't know if this configuration has Epicor's
blessing (if you call support they may just tell you to put it back on port
80). I've just started testing service connect a few weeks ago, but I've not
> Dave
Scratch that, I've found some problems. When you're creating workflows, you
can't specify the port number on a conversion. Probably a show stopper.
> IIS Manager and change the port. I don't know if this configuration has
> Epicor's blessing (if you call support they may just tell you to put it back
> on port 80). I've just started testing service connect a few weeks ago, but
> > Dave
