Excellent! Glad to hear you worked it out.. if your able to better
target your dataset and not have to worry about filtering it later
you're always better off..
Of karen_schoenung
Sent: Friday, July 10, 2009 11:19 AM
Subject: [Vantage] Re: Service Connect - return only one response from
subworkflow based on choice
Hi Rob,
Thanks for trying to help with this issue. I went a slightly different
way...I used a web service with whereclause(s) and I think I will get my
results as needed. My condition is in the where clause now.
Karen
"Karen Schoenung" <kschoenung@...> wrote:
Behalf
Of karen_schoenung
Hi Rob,
Karen
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Rob,
> I think you are right...I want to take the dataset, return header,
> detail and one sub (dead ending the rest) somehow with a condition. I
> have tried what I think is needed for conditions, but no luck, still
> always returns the first sub.
> Can you give some pointers on conditions?
> Thanks,
> Karen
Behalf
> Of Rob BucekBecause
> Sent: Wednesday, July 08, 2009 11:32 AM
> Subject: RE: [Vantage] Service Connect - return only one response from
> Ok, so they are both going to finish, then its probably a race.
> I think you're right, (from my experience) it will only roll up onepath
> or the other. Perhaps you can dead end that false using a condition.<mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> ] On
> Behalf<mailto:vantage%40yahoogroups.com>
> Of Karen Schoenung
> Sent: Wednesday, July 08, 2009 11:14 AM
> Subject: RE: [Vantage] Service Connect - return only one response fromdata
> Hi Rob,
> I am not doing anything with the false. My true does go to poster then
> finish. I think maybe it is executing only once at the higher level or
> only bringing back the first results at the higher level...My input
> is one header, one detail, one sub...But is pulling in get by id, oneheader,
> header, one or more details, one or more subs...I want to match
> detail and choose sub based on value in two fields = true.<mailto:vantage%40yahoogroups.com>
> Thanks,
> Karen
> <mailto:vantage%40yahoogroups.com> ] On<mailto:vantage%40yahoogroups.com>
> Behalf
> Of Rob Bucek
> Sent: Wednesday, July 08, 2009 10:58 AM
> <mailto:vantage%40yahoogroups.com>too
> I suppose you're one of those who like to have their cake and eat it
> right? The higher document interfaces with the finish, and since thatposter.
> is the only data you are presenting it...you could have another
> connector taking your true to the finish element as well as the
> What if anything will you be doing with your false results from thesub?
> Behalf
> Of karen_schoenung
> Sent: Wednesday, July 08, 2009 9:41 AM
> <mailto:vantage%40yahoogroups.com>higher
> Subject: [Vantage] Service Connect - return only one response from
> Hi,
> I have a subworkflow with a choice to check two fields. I send the
> result to a poster if true and to finish if false, so I can verify the
> choice is working. However, the false response is merged with the
> workflow, but I only want the true response to merge.[Non-text portions of this message have been removed]
> Any ideas?
> Thank you,
> Karen
