Service Connect - Should be an easy one
Thanks Kevin but I was able to get it to work in Service Connect.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Kevin Simon
Sent: Tuesday, July 19, 2011 1:43 PM
Subject: RE: [Vantage] Re: Service Connect - Should be an easy one....
Blake,
This maybe isn't the answer you're looking for, but is a workaround:
1. In your Service Connect workflow, set the field to "DELETE".
2. Set up a BPM with a condition of field = DELETE, and an action to
set the field to "".
It may not be the "by the book" way of dealing with it, but you'll have
it
fixed in 10 minutes.
I've gotten that clear to work in the past, but I remember it was a
pain.
It's probably been two years, so I don't recall exactly how I did it.
HTH,
Kevin
Behalf Of
Blake Clemens
Sent: Tuesday, July 19, 2011 11:31 AM
I've tried [Clear=SearchWord] or [Clear=colSearchWord] or
Clear=SearchWord... none of them worked.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of bw2868bond
Sent: Tuesday, July 19, 2011 8:22 AM
Subject: [Vantage] Re: Service Connect - Should be an easy one....
Make sure you clear the field and in the RowMod use [Clear=colName]
where colName is the field you want to clear out - you can clear
multiple columns by using a comma after each colName - I do believe the
braces are required....
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com> ,
"Blake Clemens" <blake.clemens@...> wrote:
> All you Service Connect gurus out there... I have an issue that I
can't
> seem to get past but should be absolutely very easy to figure out. I
> want to remove the value in the "SearchWord" character field in Part
> Master. What do I have to do to program SC to do this... so far all I
> can get is for the word delete to show up instead of just an empty
box.
> Do I have to set the RowMod value to delete or d???
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
All you Service Connect gurus out there... I have an issue that I can't
can get is for the word delete to show up instead of just an empty box.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
where colName is the field you want to clear out - you can clear multiple columns by using a comma after each colName - I do believe the braces are required....
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of bw2868bond
can't
box.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
and you setting a literal value on the field and checking the force empty node checkbox?
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
> Of bw2868bond
> can't
> box.
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
I wasn't checking the force empty node box... it works now. Thanks for
your help who ever you may be!!!
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of bw2868bond
Sent: Tuesday, July 19, 2011 12:46 PM
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
Behalf
> Of bw2868bond
the
> can't
I
> box.
> > Thanks,
> > Blake Clemens
> > IT Systems Engineer
> > (800) 360-2364 x132
Blake,
It may not be the "by the book" way of dealing with it, but you'll have it
I've gotten that clear to work in the past, but I remember it was a pain.
HTH,
Kevin
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of bw2868bond
can't
box.
> Thanks,
> Blake Clemens
> IT Systems Engineer
> (800) 360-2364 x132
