Anyone has the experience with Service Connect and Kinetic Upgrade? If Epicor 10.2.700.x is upgraded to Kinetic 202X, does the service connect require to be upgraded as well? Thanks a lot.
You will most likely need to touch every conversion to map newly added fields and tables – I know I did L
Thank you Bernie.
