Aaron,
I use a UD table in Vantage to accomplish this. I use it to set counters or hold temp variables that I want to pass between the parent and the sub or even other subs. It is the easiest and most reliable way I have found to do it.
--- In vantage@yahoogroups.com, "Aaron" <aaronmclements@...> wrote:
> Is it possible to setup a counter in Service Connect? I need to be able to increment for each iteration of a sub-workflow and have access to the value from within the sub-workflow.
> TIA,
