That is correct. You can process each line by line so in your case you
would not need to use cyclic execution.
Toby Boogerd
Information Systems
712-324-4854 x1119
NOTICE: This email may contain confidential and proprietary information
of Rosenboom Machine & Tool, Inc. By opening any enclosed files, the
recipient agrees not to use, reproduce, disclose, or manufacture its
contents, in whole or in part, without prior written consent of
Of cujimmy8472
Sent: Tuesday, October 23, 2007 5:35 AM
Subject: [Vantage] Re: Service Connect Workflow Designer - using cycling
execution
Perhaps you could explain in some more detail. According to the
Service Connect Course Guide p.32 'Note that the row node is
connected to the Part node to ensure that each row is treated as an
individual item.' In this example there is no sub and main process
with cyclic execution, just one process.
So correct me if I'm wrong but it seems cyclic execution does not
need to be configured to process all the records in a file with
several items.
PS I don't have the Service Connect manual - does that explain this
topic fully?
"Calvin" <calvin@...> wrote:
Behalf Of
Toby Boogerd
Information Systems
712-324-4854 x1119
Of cujimmy8472
execution
several items.
topic fully?
>line as
> An example would be processing an order file.
> You would need to cycle through each set of releases for an order
> well as order lines for each order header record.[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
> cujimmy8472i.e.
> Sent: Wednesday, October 17, 2007 3:26 AM
> Subject: [Vantage] Service Connect Workflow Designer - using cycling
> execution
> Can anyone please advise the appropriate use of cycling execution
> when to configure a process to run a sub-process in a cyclicmanner.
> An example would be ideal.an
> It might sound like a daft question but it seems all the records in
> input channel can be processed by connecting a row mapping (why is[Non-text portions of this message have been removed]
> that not in the Help file!!).
> Many thanks
