Service connect is not so bad. The easiest way to build the work flows is to
turn on tracing in Vantage and do your process manually. Look at the trace
to see which services are called and duplicate that in SC.
You can order the manual if you like but there are pdf's of it somewhere in
the install directory. At one point they were an Epicweb as well, not sure
if they're still there. You will need it to figure out how to set up message
maps and i/o channels. After that it is pretty much useless.
I attached a backup of a few of our part import processes we used for bulk
part imports. You should be able to take one, change the incoming schema and
push any part data you have through it. Most of the mandatory fields are
hard coded to "default" or something like that, so check the conversions and
make sure everything you need is right.
Have fun. Send me a message if you have trouble.
~John
PS - If you get an error that says "unable to determine message map" there
may be nothing wrong with your map. Just delete the map and rebuild it. This
is a common bug in SC.
On Wed, Nov 19, 2008 at 4:42 PM, Charles Carden <shadowcar1449@...
~John
> wrote:[Non-text portions of this message have been removed]
> Charlie,
> Send me an email to ccarden@... <ccarden%40manitex.com> with your
> mailing address. I am sure we can work out something.
> From: Charlie Wilson
> To: vantage@yahoogroups.com <vantage%40yahoogroups.com>
> Sent: Wednesday, November 19, 2008 2:16 PM
> Subject: RE: [Vantage] Re: Service Connect Workflows
> Charles,
> I was wondering if you could hook me up with one of those extra training
> manuals.
> ~Charlie
> cwilson@... <cwilson%40foamdesign.com>
> _____
> From: vantage@yahoogroups.com <vantage%40yahoogroups.com> [mailto:
> vantage@yahoogroups.com <vantage%40yahoogroups.com>] On Behalf Of
> Charles Carden
> Sent: Wednesday, November 12, 2008 7:03 AM
> Subject: Re: [Vantage] Re: Service Connect Workflows
> If you are going to use Service Connect extensively it is well worth the
> cost of scheduling a consultant to teach you. It is costly but I definitely
> recommend it. If not I have a couple of extra training manuals. Also, order
> the Service Connect Manual. I made my CAM send me one at no cost. I thought
> that was the least they could do considering the cost of SC.
> From: nmtaylor1969
> To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com<vantage%2540yahoogroups.com>>
> .com
> Sent: Wednesday, November 12, 2008 1:02 AM
> Subject: [Vantage] Re: Service Connect Workflows
> Mike,
> You definitely should get a few standard workflows when you purchase
> s/c. One of those is a part entry workflow. I would check with Epicor
> as they should give you a few to get you going.
> If not, the part entry workflow is a pretty easy one to write ( the
> PartService is one of the better behaved web services! ). I can help
> you along if you get stuck.
> Nick
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com<vantage%2540yahoogroups.com>>
> .com, "Mike
> Barnard" <mbarnard@...> wrote:
> > I just ordered Service Connect. There are no files in the Files
> > section. Anyone have any workflows they can share with the group?
> > My reason for purchasing was to bulk add new parts and to update the
> > Price Lists, and to do updates on parts like add to some UD fields
> > things I missed in the conversion.
> > Thanks for anything you can contribute, I'll certainly share any I
> create.
> > Mike
> Charles Carden
> IT Manager
> Manitex, Inc.
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.9.0/1779 - Release Date: 11/11/2008
> 8:59 AM
> Charles Carden
> IT Manager
> Manitex, Inc.
